Grinding in 4th gear... Bad synchros?
LinkBack (1) Thread Tools
Old February 17th, 2011, 07:37 PM   1 links from elsewhere to this Post. Click to view. #1
96 Mystic SVT Cobra
96SNAKE is an unknown quantity at this point
Send a message via AIM to 96SNAKE
Today, my car started grinding in 4th gear, I can't even put it in gear without it scratching so bad at me. Wondering what could be the problem? All the other gears and reverse work just fine. Was thinking that it might be a bad synchro. About how much will that cost to replace?
Any advice?
I have a 2.1L Kenne Bell for sale, polished. Pm me if interested.
Old February 17th, 2011, 07:41 PM   #2
4valvegt's Avatar
03 Cobra
4valvegt is on a distinguished road
If its not popping out of gear you can most likely get away with just replacing the blocker ring on the input shaft, if it pops out the entire syncro assembly and the input shaft will probably need to be replaced.
MM Cobra Club #86
2003 Mineral Grey Cobra
2004 True Blue F-150 FX4
Old February 17th, 2011, 07:45 PM   #3
96 Mystic SVT Cobra
Roger it doesn't pop out, but it grinds so bad.. So I just go straight to 5th gear or back to 3rd. How much to replace the blocker ring on the input shaft?
Old February 17th, 2011, 07:53 PM   #4
4valvegt's Avatar
03 Cobra
I have never had a t-45 apart which is what im assuming ur working with. Some transmissions you have to completely disassemble to get at the input shaft and some are a 10 min job just taking the front bearing cap off. A blocker ring usually ranges 10-100 bucks depending what its made out of. They are around 70 a piece in the 3650 but have a fiber insert so should be cheaper for yours. For now keep avoiding 4th like your doing so you dont chew up the teeth on the syncro sleeve and the input shaft.
MM Cobra Club #86
Old February 17th, 2011, 08:02 PM   #5
96 Mystic SVT Cobra
OK, how much to replace the synchro?
Old February 17th, 2011, 08:08 PM   #6
4valvegt's Avatar
03 Cobra
The blocker ring is part of the syncronizer assembly and is usually all you have to replace unless the surface it grabs is worn on the gear. I would say a couple hundred for the whole syncronizer assembly but i have no experience with this transmission. Your fluid is ok and full? clutch adjusted correctly?
MM Cobra Club #86
Old February 18th, 2011, 01:06 AM   #7
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
I could be wrong, but dont T45s have weak shift forks that bend easily? you could just have a bent shift fork that doesn't put it in 4th all the way. I am probably wrong though...
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old February 18th, 2011, 09:24 AM   #8
96 Mystic SVT Cobra
Okay thanks, guys.
Old February 18th, 2011, 08:09 PM   #9
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Yes, T-45's are known for bent shift forks.
Old February 19th, 2011, 12:56 AM   #10
4valvegt's Avatar
03 Cobra
More than likely not a shift fork if its not popping out of gear, if the shift fork is bent most of the time the sleeve wont slide all the way over the gear and they pop out.
MM Cobra Club #86
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/204671-grinding-4th-gear-bad-synchros.html
Thread Grinding in 4th gear... Bad synchros? | Forums at Modded Mustangs | BoardReader This thread Refback July 31st, 2011 07:57 PM
Threads Similar to: Grinding in 4th gear... Bad synchros?
Gear grinding Sinister 99-04 8 January 29th, 2011 11:31 AM
3rd Gear Grinding CandyredGT 2005 - 2010 26 June 9th, 2010 05:20 PM
gear synchros skuzzy Modular Mustangs 5 December 6th, 2009 06:30 PM
5th gear grinding emgjsdk1 99-04 4 March 6th, 2008 09:51 AM
1st gear grinding Luis_GT 2005 - 2010 9 April 4th, 2007 07:05 AM
