98 Cobra Engine Squeal help!
Old February 19th, 2011, 07:18 PM   #1
ttakethereinsr's Avatar
98 Mustang Cobra
ttakethereinsr is on a distinguished road
Exclamation
so i bought my car a few months ago with some issues. It needed a IMRC Controller and new head gasket. I got it back and the car has a constant squeal. It did not squeal before the head gasket job. When i put the clutch in the sound stops. The car has 125k on it. Any help would be appreciated! thanks
Old February 19th, 2011, 07:27 PM   #2
1999cobra92's Avatar
1999 mustang cobra
1999cobra92 will become famous soon enough
i belive its the throw out bearing in the trans.
Black and White Crew
Crew Member # 5
Check garage for mods and pics
if you Los Angeles and want to ride send me a text (323) 270-6827
0% Wheel hop, 0% broken parts, 100% wheel spin
Old February 19th, 2011, 07:32 PM   #3
1999 mustang cobra
also might be the clutch or flywheel
Crew Member # 5
Old February 22nd, 2011, 09:43 AM   #4
1996 Cobra
BlackSnake135 is on a distinguished road
its your throw out bearing.. same thing happened to me in my 96 cobra
Old February 25th, 2011, 03:38 AM   #5
Petty886596's Avatar
1996 Cobra
previous owner said he ran 13.5s Ill see what I can pull off this spring
Petty886596 is on a distinguished road
+1 on throw out bearing
Old February 26th, 2011, 05:07 PM   #6
mustang3194's Avatar
1996 Mustang Cobra
mustang3194 is on a distinguished road
Send a message via AIM to mustang3194
Throw out bearing
95 Mustang swapped to a 96 Cobra Drivetrain
Old February 28th, 2011, 12:54 AM   #7
dudelinger's Avatar
1997 Mustang Cobra SVT
soon!
dudelinger is on a distinguished road
Yep, throwout for sure, make sure when u pull out the trans, check
For galling/wear on the retainer snout
8:1 HCI built motor, D1SC Procharged/intercooled,custom ground cams,HCI intake manifold,MSD dig ignition,KOOKs Full Lengths,MM full tubular,Pro-motion tko 600, 3" Bassani xpipe,Magnaflows,much more! 625RWHP/510RWT
Threads Similar to: 98 Cobra Engine Squeal help!
Wheel squeal? WTF? Twatwaffle 2005 - 2010 5 August 24th, 2010 11:49 AM
Extreme squeal RyanGT 99-04 41 January 24th, 2009 11:41 PM
Squeal From Under The Hood JustinSane V6 Mustangs 28 October 14th, 2007 09:26 PM
squeal at startup sasafrass12 94-95 2 August 18th, 2007 06:14 PM
Brake squeal help PaperCross 2005 - 2010 13 April 18th, 2007 12:00 PM
