fr500 cam kit
Anyone installed this in a 99 or 01? Good, Bad, interested to hear. Suggestions.
01 Cobra Jlt Cai,BBk Lt's/cut- outs,mids/cats,magnaflows. Twin 65tb. |
MM's Orangest
2004 Mach 1 Mustang
I've got them in my Mach. They're ok, but I'd take the money you would spend on them and get some custom grinds for a little more and get better results.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
PM na_svt
He will help you decide what you want to do if you do custom grinds. He's the man when it comes to normal aspiration.
1998 Gt full pi swap -Dead and gone 1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver 1998 BAB Cobra-Project |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
if you arent doing anything aggressive, you wont need a set of custom grinds. the FR's are a good mild cam, but they are a mild cam.
4v Know-it-all
The aggressiveness of the specs has nothing to do with whether or not he would benefit from custom cams.
FRs are great cams but require springs, but they are longer available. I bought the last 7 kits from Ford about a year ago and they are pretty much non-existent these days. Occasionally you will see the cams in the classifieds but you would still need springs. Lastly, the install will cost twice as much if you go with cams that need springs. The FR500 specs are 212/208, .472" lift with a 109LSA, no advance. Stock 96-98 cobra cams have 204 deg dur so the FRs are very mild in comparison. They do have more lift but lift means little on 4vs unless the heads are ported in a way that increases high lift flow. Custom cams will give you alot more power and if the lift is .450 or less you can use the stock springs. I can get a Mach to 370rwhp with a set of cams that use stock springs. Last edited by na svt; February 21st, 2011 at 10:37 AM. |
Assistant to the Manager
I was thinking when he said cam kit...he also had the springs...
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng |
Threads Similar to: fr500 cam kit
| fr500? | PsnSnake_19 | 99-04 | 20 | August 21st, 2010 03:29 PM |
| Fr500 Cam Kit | Eddie25u | 4V / SVT | 7 | October 1st, 2009 06:40 PM |
| FRPP FR500 vs AM FR500 | njstang | 99-04 | 19 | April 8th, 2009 11:00 AM |
| FR500 help | energiesource | 99-04 | 14 | December 9th, 2007 01:26 PM |
| fr500 | lemon | 99-04 | 22 | July 23rd, 2007 02:31 AM |
