98 Cobra trans won't go into gear
Old February 22nd, 2011, 07:07 PM   #1
jqualls04GT will become famous soon enough
Just as the title says, my roommate has a 98 cobra, manual trans, that he bought all stock and has only done exhaust and springs to it. The problem is the shifter won't go between gears left/ right, or into the one's it is in line with. We took the shifter out, and it won't move any more using a ratchet handle for leverage. Any ideas what it might be?
31-Spline upgrade in progress!!
My stang burnout vid!
Old February 23rd, 2011, 10:32 AM   #2
Petty886596's Avatar
1996 Cobra
previous owner said he ran 13.5s Ill see what I can pull off this spring
Petty886596 is on a distinguished road
sounds like the shifter fork/rod take the top of of the transmission off. there should be a roll pin in the piece that the shifter sits in get a punch and knock that down. once you have it out there will be a ball and a spring under the handle.Once you do that you should be able to remove the nose and top of the tranny .Then visually inspect the shift forks and rod for cracks or bends.Dont scrap the tranny for a 35 dsollar fix...people do that everyday ands it sickens me!!!!!!!!
Old February 23rd, 2011, 02:54 PM   #3
I'm glad I'm on leave, I got plenty of time to try that, thanks
Old February 24th, 2011, 04:19 PM   #4
Do I have to drop the trans to check the shift fork/ rod?
Old February 25th, 2011, 02:33 AM   #5
1996 Cobra
ohhh yeah you have to drop it....its not that bad but if you have never been into a tranny it can be scary at first but, imo its alot easier to rebuild a standard transmission than a engine. Just checking the shift forks is pretty easy look online for write ups on it they should be all over the place. One of the t-5s in a fox I own was sold to me for $1000 because the tranny was bad (it was stuck in neutral) when we opened it up the shifter rod was rusted so bad it wouldent move at all and that was it replace the rod and it was done.My uncle has 96 v6 and it would not go into first or, second it was the shift fork. Then again you never know what you will find once you get in there. Oh btw you will want the transmission in neutral to remove the roll pin from the shift rod.
Old February 28th, 2011, 01:13 AM   #6
dudelinger's Avatar
1997 Mustang Cobra SVT
soon!
dudelinger is on a distinguished road
And if your friend cant figure it out, he should get rid of that t45 and throw a TKO in it( but throw away that shifter they come with and get a good steeda/pro 5.0)....good luck!
8:1 HCI built motor, D1SC Procharged/intercooled,custom ground cams,HCI intake manifold,MSD dig ignition,KOOKs Full Lengths,MM full tubular,Pro-motion tko 600, 3" Bassani xpipe,Magnaflows,much more! 625RWHP/510RWT
Threads Similar to: 98 Cobra trans won't go into gear
Trans Whine and 3rd Gear Crunch AnotherS197GT 2005 - 2010 14 December 1st, 2010 06:38 PM
gt trans in cobra superbean 4V / SVT 7 August 17th, 2008 01:15 PM
Trans Problem (First Gear) brianm 99-04 4 November 14th, 2007 08:25 AM
Question on AOD Trans - No 3rd Gear....Help please!!!!! TomF514 5.0 Mustangs 4 January 7th, 2007 01:55 PM
