2003 Mustang Mach 1
14.60@95.72
Service Engine Light
Hey guys I own a 2003 Mach 1 with just over 8,000 original miles. My service engine light came on and I went and got the code for the car but cannot seem to find the problem. The code is: P0420. I recently got rid of the stock Hpipe and got a Xpipe, so I was wondering if anyone has gotten this code before and how did you fix it? Thanks alot!
Because Racecar
2012 Mustang GT Premium
8,000 original miles!? I hate you...
Maybe your O2 sensors. |
Because Racecar
1999 SVT Cobra
Any cats? If not, sounds like that's it.
2003 gt
5.4 32v on the way
get a handheld and turn off the rear o2s and the problem will likely go away if it just sarted after changing your mid pipe.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
2003 Mustang Mach 1
14.60@95.72
Yes it is a catted Xpipe and the code came on before so I switched out the Hpipe and put the Xpipe and the code still remains.
MM's king of Neon's
404 - car not found
17.81@87
I believe P0420 is catalyst below efficiency threshold. I know its an O2 sensor related code, but not 100% sure thats it. You should be able to look it up.
If you do have cats check for exhaust leaks, between the upstream and downstream O2 sensors, as well as check your O2 sensors. You can check them with a blowtorch and DVM if you'd like. But easiest route is to just run MIL eliminators, or if you have a tuner turn them off. Problem solved. If you want to know how to check your O2 sensors with a torch let me know and I'll post it up.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2003 Mustang Mach 1
14.60@95.72
I think I may have an exhaust leak because there is a puttering sound when at idle. How can I detect where the noise originates?
Because Racecar
Put it in the garage and shut the door, turn engine on and leave on. If you start getting sleepy, you have an exhaust leak.
But seriously, don't do that... I don't need the police showing up for assisted suicide... Well, obviously since you have new mids, if they weren't welded and just slipped on that would be the first place to look. |
2003 Mustang Mach 1
14.60@95.72
Thanks guys for the help I'll have to check it out tomorrow or this weekend. Just one more question, will there be some sort of evidence where the leak is exactly coming from?
MM's king of Neon's
404 - car not found
17.81@87
Large carbon deposits are usually a give away, but it may not have them if it's fairly new. Otherwise you'll have to rely on hearing/feeling the leak out.
1997 Mustang Cobra SVT
soon!
Catalyst efficiecny code, im assuming you dont have cats, or the ones you put on arent cutting it. you need the eliminators like he said^^^^
8:1 HCI built motor, D1SC Procharged/intercooled,custom ground cams,HCI intake manifold,MSD dig ignition,KOOKs Full Lengths,MM full tubular,Pro-motion tko 600, 3" Bassani xpipe,Magnaflows,much more! 625RWHP/510RWT |
Threads Similar to: Service Engine Light
| Battery Light/Service engine soon light | Genevieve! | 99-04 | 21 | March 12th, 2011 10:51 AM |
| Service Engine light | Squints | All Other Vehicles | 3 | March 5th, 2010 03:41 PM |
| Service Engine Light | PowerShiftz02GT | 99-04 | 13 | May 20th, 2008 09:28 PM |
| Service Engine Soon Light? | joka187 | V6 Mustangs | 7 | December 13th, 2007 01:02 PM |
| Service Engine Light | Vettefast | 2005 - 2010 | 7 | November 27th, 2007 10:48 AM |
