Motor Install HELP!
Old March 1st, 2011, 10:54 PM   #1
Underground
2001 SVT Cobra
BigEag205 is on a distinguished road
Motor Install HELP!
So, i got the motor out fine and got it built, now its time for the install. I have the spline of the tranny in the clutch and everything, the motor is sitting on the motor mounts, but the edge of the stud on the mount is touching the outside edge of the whole its suppose to go in... Any suggestions on how to get it the rest of the way in, any hints, secrets, etc?! Ive been goin at it for a few hours and havent been able to get it >=( ive tried readjusting the mount of the hoist and everything possible that pops in my head including man handling it trying to rock it in. ANY HELP IS GREATLY APPRECIATED AT THIS POINT, including just setting it on fire, haha
Old March 2nd, 2011, 10:36 AM   #2
mustang3194's Avatar
1996 Mustang Cobra
mustang3194 is on a distinguished road
Send a message via AIM to mustang3194
Solid or poly mounts. If they arent solid just use a crow bar and move it out a bit or if that doesnt work put the mount on the engine and drop it in with the mounts attached
95 Mustang swapped to a 96 Cobra Drivetrain
Old March 2nd, 2011, 12:38 PM   #3
dudelinger's Avatar
1997 Mustang Cobra SVT
soon!
dudelinger is on a distinguished road
and you say you have the splines in the clutch, is the trans bolted flush to the block with the shaft in the pilot bearing? is the trans mount still hooked up? if so, then you might be bottoming out the top of the trans on the floor board and it can be pretty tight, you might need to undo the trans mount or even lower the cross member a hair by loosening the 6-8 bolts
8:1 HCI built motor, D1SC Procharged/intercooled,custom ground cams,HCI intake manifold,MSD dig ignition,KOOKs Full Lengths,MM full tubular,Pro-motion tko 600, 3" Bassani xpipe,Magnaflows,much more! 625RWHP/510RWT
Old March 2nd, 2011, 03:11 PM   #4
1999 Mustang Cobra
jamiehatch is on a distinguished road
Just try prying on the motor mounts. Is the transmission bolted up?
Old March 3rd, 2011, 10:29 AM   #5
Underground
2001 SVT Cobra
yes the transmission was bolted up and the beginning of the shaft was seeming to go in the clutch but the splines werent goin in. I took it as the clutch wasnt lined up right for the splines to slide in correctly. honestly, after 2 days of messing with is and trying to move the clutch to the right spot i just took it to the garage. they called me about an hour ago saying it seemed the EGR piping was hitting the fire wall but i personally pulled the motor out with the EGR valve and piping on it and know that shouldnt be the problem. I should be hearing something within the few hours as to what the problem was. Its been in the shop getting a 301 forged bottom end and i was tired of having the motor done and not in trying to mess with it so i sent it away so I'd have it by the weekend.
Old March 3rd, 2011, 11:00 AM   #6
Underground
2001 SVT Cobra
and the mounts are poly btw
Threads Similar to: Motor Install HELP!
Motor Mount install bbrewer03 96-98 16 October 9th, 2011 11:02 PM
motor install help! (central fla) ZoomZoomMFer Southeast 1 July 31st, 2010 08:22 AM
3.8L to 4.6L motor swap install. Hope this can help some 1. TennesseeMustangPerf V6 Mustangs 49 May 12th, 2009 07:23 PM
Are motor mounts hard to install? Zurdo03GT 99-04 11 March 14th, 2008 12:12 PM
motor mount install nolife 5.0 Mustangs 0 March 2nd, 2008 10:13 PM
