Has anyone had or have this problem.."99 Cobra"
Old March 2nd, 2011, 09:13 PM   #1
2004 mustang
tommyboy2008 is an unknown quantity at this point
Angry
ok, I put up a post before but didnt get any help. Here's the problem..
Just swapped my v6 with a 99 cobra engine a T-45. I got everything together, tuned it to turn pats off and exhaust upgrade. It fired up on the first try. Great rite? well now its time to work out the bugs. I got them all worked out except this one thats driving me crazy. ....When its at idle (about 850rpm) and I give just a tiny bit of throttle...its wants to stall out. Not completely, but damn near. So i thought it might have been the cop's since EVERY sensor is brand new. O2 sensors, IAC, TPS, ect. So I had an idea to unplug the MAF and bam problem disapeared! so wtf. Thats when I bought a new MAF and it still hesitates when you gas it and wants to stall when opening the throttle a little. Im at a dead end. I also checked and double check the vacuum lines and my pcv had a little leak so I fixed that and no help. I also reset the computer and ran the recon software that came with my special forces tuner and everything checks out. O2 sensors are running around 50 which is perfect, so I dont know. Is it running too rich or too lean maybe? How can I check that "besides puling a spark plug to see if its black or white", I want a number. whats the air fuel ratio supposed to be? The guy at special forces told me "Thats normal" This isnt normal...HELP IM GOING NUTS OVER THIS!!
Old March 2nd, 2011, 11:56 PM   #2
mfj
2001 Cobra
mfj is an unknown quantity at this point
Did you switch out the wiring harness and are you running the 99 Cobra computer?
2001 Cobra- Stroked/Poked/Cammed/Blown
1996 Cobra- CF Clutch/STS/Lowered/CAI- otherwise stock... The daily driver...
[SIZE="5"][B][COLOR="Blue"]MM Cobra Club #3.4[/COLOR][/B][/SIZE]
[SIGPIC][/SIGPIC]
Old March 3rd, 2011, 09:26 AM   #3
4v Know-it-all
na svt is on a distinguished road
the a/f should be 14.7:1 while cruising and at part throttle and 13.0:1 at full throttle.
Old March 3rd, 2011, 07:40 PM   #4
2004 mustang
thanks guys...I got the problem fixed. Its was what I figured it would be. It was the tune..aparently the manifold air volume was off, so I sent special forces my tune by email and the guy changed that and something else..not sure what it was but the car runs PERFECT now! sweet! So if anyone has put a tune on their mustang and suddenly have hesitation problems, check the manifold volume...
Old March 3rd, 2011, 07:41 PM   #5
2004 mustang
oh, and yes I changed every single wire in the car including the computer to 99 cobra..
Threads Similar to: Has anyone had or have this problem.."99 Cobra"
NEED HELP! Think i have a problem with "PATS" Passive Anti Theft System. 1badSN95 96-98 5 December 10th, 2010 09:33 PM
Classic "vents on defrost" problem Atlus General Tech 1 October 18th, 2008 09:23 AM
The classic "stuck on defrost" problem Atlus V6 Mustangs 7 October 9th, 2008 01:39 PM
Engint "tick" problem 96cobraclone 96-98 0 October 4th, 2008 05:13 PM
