Fuel Pressure Problems
Old March 3rd, 2011, 07:30 PM   #1
bigz5000's Avatar
1998 Mustang Cobra
bigz5000 will become famous soon enough
My car was bogging down + having a short issue so i took it to the stealership...
Had a loose connection right out of the fuse box, and they said i was loosing fuel pressure inbetween the tank pump, and my trex pump. Oh...and they wanted $900 to do it...
So i dropped the tank to find out that i have a 95 Cobra Tank instead of a 98...But the good part is the Walbro 255 Pump was only $135. Put the pump in...same problem. So i replaced the fuel filter, even though i could blow through mine...same problem. Any Ideas
Car bogges down when i smash the gas, but is ok keeping it conservative and under 3k rpms or so...
Thank
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner
Threads Similar to: Fuel Pressure Problems
96 4.6 fuel pressure problems! 72chevellephil 96-98 3 July 11th, 2010 05:29 PM
96 mustang gt fuel pressure/a few other problems HELP PLEASE articwhite 96GT 96-98 12 May 30th, 2010 04:05 PM
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 11:41 AM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 06:58 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
