1996 Mustang Cobra
03 blower on a 96
I know its a lot of work but i'm thinking about doing it anyway. There's a guy in town with a 03 cobra blower, fuel pump, heat exchanger, 39# injectors, fuel rail, and many other parts. What would i all need to do this? I know i need the lower intake, timing chain cover, alternator relocation bracket and some other stuff. I will have to lower the boost due to possible engine frag.
![]() 95 Mustang swapped to a 96 Cobra Drivetrain |
2001 Cobra
14.2@102 (I suck)
Well, I'm not sure what EVERYTHING you need is, but there are easier kits out there that I know someone will chime in and suggest.
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
4v Know-it-all
You will need to change the heads because the 03/04 intake only fits C heads. Also, your engien will hold up to all the boost that an unported eaton can provide.
#4 | |
![]() 01 GT - 32v swap - Bassani - Spec - Mac
4v Know-it-all
a stock harness and computer will work as will the stock fuel rail (with minor mods).
1996 Mustang Cobra
Well the eaton is not stock its running like 14lb of boost, i would have to turn it down for now. The guy selling it put on a KB running 30lb and well over 700hp
MM's king of Neon's
404 - car not found
17.81@87
There is a crapload of parts. Search Lefty's Eaton swap thread. You'll need all those plus C-heads.
It's far from simple. I just bought a swap kit and seperate from the timing cover, intake/M112 assembly, and heat exchanger, I have a giant blue bin of the remaining parts that's well over 100lbs. There's tons of parts required, but if you can get them all, and cheap, and don't mind lots of work, go for it.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
Threads Similar to: 03 blower on a 96
| if a roush tvs blower fits a 4.6L then can a GT 500 blower be retrofitted? | navyman8903 | 2005 - 2010 | 64 | August 29th, 2009 04:23 PM |
| Looking for a 6-8 lb. blower? | bossman2kgt | 99-04 | 4 | September 8th, 2008 09:51 PM |
| Blower Q,Mad max | spike spiegel | The Clubhouse | 27 | June 6th, 2008 06:10 PM |
| BIG blower | BWAL | 5.0 Mustangs | 17 | June 6th, 2007 06:32 PM |
