Looking for a Terminator, what to watch for???
Some of you may have noticed in another thread i started that i recently got screwed out of a killer deal on a modded, low mileage mach...I always wanted a termi, and losing that mach made me have to find a termi...
All cars have known issues, or weak parts, weak areas etc...like my 95 has a sensitive computer and a gangster lean to name a few... what do i need to know bout the termis? Crap aftermarket parts that i should try and avoid? should i avoid highly modified ones? Stay away from high mileage ones?? would u buy one with more than 75,000 miles? 100,000? thanks j
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
2003 SVT Cobra
Its all about what you want to spend. As far as highly modified ones, just make sure that it was tuned properly and you shouldnt have issues. Get a digital wideband if it doesnt have one. If it is highly modified and has the stock tranny (10 spline) that will be your weak link. As far as mileage goes, the only really known issues for the terminators to have are the alternators and the head tick that some have if it hadnt been fixed. There maybe more but nothing sever. Mileage depends on price, lower mileage the more they cost of course. Any particular colors your going for? Coupe convert?
2003 Sonic Blue SVT Cobra - 711 RWHP @ 671 TQ @17psi. Kenne Bell 2.8, FRPP Modular Boss 5.0 block, Big Bore 324ci Stroker, JDM Stage 3 Heads, Extreme Stage 3 Cams. 4,900 original miles......... Currently at Street Lethal Performance! |
Zoolander
04 Cobra #2260/3768 1/820
Buying a cobra is a bit difficult when used. I learned that the hard way. Get the car fully looked over. You will thank yourself later, and don't get your hopes up on one. If the irs is stock save up to modit or do a SrA swap. The alternators have been known to go out, and they are a bitch to change. For me...the whole damn car was driven into the ground.
#4 | |
what is the head tick issue? recall? what is the fix? i guess i would like to find a stock one, or mostly stock..those have probably been beat on a little less..or atleast the engine was operating within spec during those times.. i think i would be happy with a vert or a coupe...definitely dont want the light grey...love the blue, red and yellow, but not sure i would like to own a yellow one...
2003 SVT Cobra
I know ford did replace some of the head ticks. Iv personally never owned one or even heard the head tick from any terminators but some are still out there. I have a lack of knowledge on what causes it and how it is fixed. Like stated above, make sure the car is looked over well, especially if it has higher miles on it. As far as the alternators go, they are a b*tch to get off and its poor location of it cant help but to shorten the life of one due to water and dirt that can reach it being down so low. Unless one has really been beat on, I dont think you will have much trouble with most that you will find. If there is one modded, verify everything with the company that did the modifications. Thats exactly what I did with mine b4 I put any type of payment down. I couldnt be more happy with my purchase. Best of luck and keep us posted!
Resident DJ
'01 Cobra Vert.
Oh hai Cricket
![]() Where the hell have you been JP?!
Zoolander
The irs SrA thing do research on what you want. The forged internals are sobthat the internals last longer, and can handle more pressure and power. And its not as much for spending 10g to get it where you want. I was more or less spending that to keep it on the road.
Hey troy. I've been busy with moving out, practicing and playingpartoes and such I dj for. That's my new thing and I blame Primo. Im kinda obsessed with it. Just really haven't had time for the site, but I didnmiss it a bit. |
Noob Slayer
13.82 @ 101.09
If you are going to DD the car stay IRS (coming from someone with a SRA).
![]() 2003 Black Cobra 10th Anniversary 2.8 Kenne Bell Mammoth LC - Built SRA - T56 - E85 - Spray - Stock Longblock - True Forged Mach 5s 2004 Silver GT 5 speed - SOLD MM Cobra Club Member# 97 |
it would not be a DD for me, but why switch in the first place?
2001 Cobra
14.2@102 (I suck)
The IRS has lots of soft rubber in it and there are lots of technnical things blah blah wheel hop blah leaking diff cover blah blah broken halfshafts blah not made for hard launches. It was designed for comfort and compatability over strength and performance. Basically drag launching it will cause parts to fail, whereas the SRA is bulletproof by comparison. Personally, I wish the previous owner didn't do the swap but hey at least I don't have to worry about it on the rare occasion I do go to the drag strip
lol
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
#11 | |
Noob Slayer
13.82 @ 101.09
2003 Cobra
People love to hate and hate to love the IRS.. from what I read this is mostly cured with a (and correct me if I am wrong I am NO Cobra specialist and a new owner) IRS brace, diff cover girdle, and all the bushings upgraded to polyurethane
yeah i am kinda hearing that too...i think i would keep the IRS because i like the twisties more than launching hard...however, i cant handle wheel hop...i would consider switching to a Str8 axle if i counldt get that resolved.
2001 Cobra
14.2@102 (I suck)
You can get a kit that replaces all the rubber bushings with aluminum ones. It supposedly is the cure-all method for the IRS but i've yet to talk to someone who actually installed the kit. I can understand how it would fix all the problems coming from the rubber bushings...but what kind of increase in NVH will it cause?
Common issues are TOB/Retainer shaft (Easily replaced) IRS causing wheel hop (Easily fixed with FTBR.com kit) cars running lean (Dyno Tune and Wideband guages) beaten on (Driver Mod required) and Clutch depending upon what horespower level you are running at.
Cooling is kind of an issue because it takes effort/understanding/concentration to burp air bubbles out of the Engine Cooling system, and the Supercharger IC system sometimes gets ignored by people. Here is a great reference for anyone new to Terminator Cobras. Terminator FAQs
![]() Born 03/26/04 #3682 of 3,768. Only 85 coupes built after mine. 3/31/04 THE LAST COBRA WAS BUILT. 2.6L KB, 63#, Griggs GR-40, Koni, lots of crap MM Cobra Club #666 |
Best place to find them here: Terminators Buy/Sell - SVTPerformance
#17 | |
2003 Cobra
Sorry. Correct URL Full Tilt Boogie Racing
If you care they have killer videos to learn you up on really good info about IRS suspension.
#19 | |
2003 Cobra
Threads Similar to: Looking for a Terminator, what to watch for???
| Terminator Fox... | 1FastFox | 5.0 Mustangs | 10 | June 21st, 2008 10:55 PM |
| MY fav. terminator vid =) | Invictus | Videos | 4 | March 20th, 2007 07:25 PM |
| Terminator | Mustang RacR94 | V6 Mustangs | 28 | February 2nd, 2007 06:22 PM |
| best terminator vid | matrixpuba | Videos | 17 | January 20th, 2007 09:10 PM |
