Mark viii short block
Old March 14th, 2011, 12:31 PM   #1
1990 mustang lx
jesusm3 is on a distinguished road
I got offered a short block from a 1998 mark viii for $250. I am planning on building a drag car for my daughter and so when she gets old enough that is something we can do together. I plan on goimg with a fox. I have a dd fox so I am not new to them, but I am new to the 4.6. If you can give me any input it will be greatly appreciated
Old March 14th, 2011, 12:41 PM   #2
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
for a fox i would build a 302 or 351, probly cheaper and easier to fit in the fox
o and less weight
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old March 14th, 2011, 01:04 PM   #3
1990 mustang lx
Ive been doing reasearch and come to find out it seems to be cheaper to build a 4.6 than a 5.0.
Old March 14th, 2011, 01:27 PM   #4
bitemark46 has a spectacular aura aboutbitemark46 has a spectacular aura about
Mark 8 shortblock= Teksid block (keep it). The rods and crank are the same junk they put in the 96-01 n/a cobras so if you plan to upgrade do h-beams and a quality piston. The crank is cast (same ast the gt's).
-Mark-
98' N/A Cobra (Stock longblock)
11.79 at 114.64 (1.62 60ft)
Old March 14th, 2011, 08:11 PM   #5
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
If the shortblock is good. Go cheap.
PI heads (net you 11:1+comp)
PI cams or aftermarket
Edelbrock intake
6061 elbow
75mm throttle body
Longtubes
Right there is a 330+rwhp combo...get some ported (livernois CNC'd) heads, and it will clear well over that mark. That would be plenty fast for most...
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old March 14th, 2011, 08:19 PM   #6
1990 mustang lx
Are thr stock b heads worth keeping?.
Old March 14th, 2011, 08:32 PM   #7
1990 mustang lx
Keeo in mibd this will be 90% drag car
Old March 14th, 2011, 08:34 PM   #8
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
Depends...Mark heads are just a bit inferior then the cobra heads. But still flow.
If you plan on stayin NA...um...prob not. It won't make good power unless you cam it, spin it and put some compression in it...
96 GT-Cammed E85
www.KPERacing.com
Old March 15th, 2011, 12:39 AM   #9
1990 mustang lx
How cheap would you go?
Old March 15th, 2011, 11:06 AM   #10
majorownage is on a distinguished road
what are you talking about? they are exactly the same head
4v>2v
1998 Gt full pi swap -Dead and gone
1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver
1998 BAB Cobra-Project
Old March 15th, 2011, 05:11 PM   #11
There is a small difference in the bowls but probably not noticeable on a dyno.. Big difference is the cams. Mark 8 cams are less agressive compared to 96-98 intake cams. Full bolt-on B-headed cobras can make 320-330rwhp.
-Mark-
Old March 15th, 2011, 09:14 PM   #12
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
4v>2v
Lol. Majorownage is correct for your name.
Thanks Mark.
You will prob see a diff in the dyno. Maybe no where else. The bowls come in and surround the valves...Cobra heads do not do that.
96 GT-Cammed E85
www.KPERacing.com
Old March 15th, 2011, 09:23 PM   #13
Thanks Mark.
maybe on older mark viii heads...
I have a set of 98 mark viii heads in my garage and a set of 98 cobra heads.
They are exactly the same....except of the cams of course.
Old March 16th, 2011, 07:37 PM   #14
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
Every Mark head I have seen has this. If you got a set that don't. Check the casting number.
96 GT-Cammed E85
www.KPERacing.com
Old March 17th, 2011, 03:13 AM   #15
mfj
2001 Cobra
mfj is an unknown quantity at this point
I don't know what you consider "research" but you are WRONG. It is so much cheaper to build a pushrod motor than a quad cam mod motor.
2001 Cobra- Stroked/Poked/Cammed/Blown
1996 Cobra- CF Clutch/STS/Lowered/CAI- otherwise stock... The daily driver...
[SIZE="5"][B][COLOR="Blue"]MM Cobra Club #3.4[/COLOR][/B][/SIZE]
[SIGPIC][/SIGPIC]
Old March 17th, 2011, 09:41 PM   #16
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
^ Um. Not if you do it right. Most bolt on HCI 5.0s I seen barely clear 300rwhp. Put a fresh 306 in it and up the compression just a tad and you MIGHT get 330rwhp. I know cause ive done it.
A stock lincoln aviator motor can be had for 1500, add cams at 990, longtubes and a tune. Thats 350-380rwhp depending on the cams and intake...Um...most good 5.0 heads are 1200+...mind you...the 4v is a stock longblock with cams making more power than 5.0s with HCI...
96 GT-Cammed E85
www.KPERacing.com
Old March 19th, 2011, 03:40 AM   #17
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
Bueller....Bueller...???..anyone...
Where you at MFJ???
Funny part is...you drive a 4 cam. lol.
96 GT-Cammed E85
www.KPERacing.com
Old March 19th, 2011, 04:18 AM   #18
mfj
2001 Cobra
Where you at MFJ???
You completely missed my point. In terms of absolute cost, building a pushrod motor is MUCH cheaper than building a 4v. It's not up to negotiation. That's just how it is. And if you are not paying for labor, the amount of "sweat equity" you will have in your 4v is much more than a pushrod motor.
And yes I drive a 4v. If I had to do it all over again, I would have done a built LQ9 GM pushrod engine and a couple of snails, and still wouldn't have spent even close to what I did on my current set up.
The heads and OHC is what makes everything so much more expensive. 4 cams instead of one. 4 times the valve springs. I think you get where I'm headed with this. Valves, retainers, etc...
[SIGPIC][/SIGPIC]
Old March 19th, 2011, 04:31 AM   #19
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
I really want to vote for the mod motor being better money spent if you want a chunk of hp but I have not sat and priced anything. 4v heads and cams could be left alone if the cost of dealing with 4 cams and 32 valves is really a big deal. Plenty of 03-04 cobras seem to be doing just fine with what ford gave them. I think that by what it takes to make decent hp, price shouldn't be an issue and you should just do whatever you would enjoy most. Stock mod rods break ~450, and that could just as easily be the case with a 302 block. I guess FI is FI and its probably going to cost about the same for either so you are stuck with block, rotating assembly, heads, cam and intake for the 302 vs rotating assembly and maybe cams for the more expensive 4v 4.6.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old March 19th, 2011, 05:21 AM   #20
mfj
2001 Cobra
Well yeah. In the specific case of Ford, they jewed their customers with a shitty block back in the days of the 5.0 Foxes. Dart blocks can handle anything but are expensive as shit. GM got it right with their LSx engines which are still, to this day, the best bang for the buck you can get for hp. And much easier and cheaper to build than a Ford Mod motor.
[SIGPIC][/SIGPIC]
Threads Similar to: Mark viii short block
96 mark viii majorownage 4V / SVT 4 August 18th, 2010 02:50 AM
Mark VIII MikeJones 99-04 34 February 4th, 2010 06:22 PM
Will Lincoln Mark VIII block work on 1998 Cobra? cobra98sd 96-98 14 December 27th, 2009 03:18 PM
mark viii into a 03 gt fordman1023 4V / SVT 1 December 27th, 2009 02:12 AM
Mark VIII help? John's_stang 99-04 10 April 9th, 2009 02:30 AM
