Doing some Routine Maintenance soon, suggestions?
LinkBack (1) Thread Tools
Old March 14th, 2011, 09:26 PM   1 links from elsewhere to this Post. Click to view. #1
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
Well, finals are over on Friday and I have a few days free at home before flying out to Colorado. I figure what better way to spend my time then work on my car, right? Anyways, there are a few things I already have on the list that I'll finally have time to do because I won't be at school. I posted this in the 4V section in case you Cobra Bro's know some secret tips or anything I should look into while I have the time.
So far these are the things I have planned:
clean air filter
Oil change- hasn't been too long but easy and I'll have the time.
Transmission fluid change- probably unnecessary but someone mentioned a certain oil/friction modifier combo that would smooth the notchy pro50. (T-56)
Brakes-maybe depending on how bad. Recommended brands? otherwise going stock.
Maybe diff fluid and spark plugs...probably not.
Other than that, just a nice quality detail job and I'm set. Is there anything I should look at that isn't already mentioned? What are the best brands for the various parts? The car is my DD but I take it up in the Santa Cruz twisties every now and then, 74,000 miles on the odo. I'm doing all this myself and all I've got is a floor jack and two stands, so no pulling the engine lol.
I assume Prestone is the coolant/antifreeze of choice?
One last thing: I bought the car with no Cobra grille logo, some punk ripped it off. The bracket is still there though. Do I have to pay $20 for a new grille emblem or can I grab a fender emblem cheap and glue it on?
Thanks in advance guys.
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old March 15th, 2011, 08:55 AM   #2
Aceswild 02's Avatar
2003 Cobra (vert)
Aceswild 02 is just really niceAceswild 02 is just really niceAceswild 02 is just really niceAceswild 02 is just really niceAceswild 02 is just really nice
"Transmission fluid change- probably unnecessary but someone mentioned a certain oil/friction modifier combo that would smooth the notchy pro50. (T-56)"
tell me more...
For brake I would go with Hawk HPS pads and DOT 5.1 or better fluid. Why? Because Jazzer the Cat said so.
MM Cobra Club #2.6
Old March 15th, 2011, 09:13 AM   #3
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
tell me more...
Lucas Tranny Fix is what you add to it.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old March 15th, 2011, 02:16 PM   #4
2003 Cobra (vert)
It looks to be an additive that you can put in at any time. Is this correct? And it really makes the shifter feel noticably smoother?
MM Cobra Club #2.6
Old March 15th, 2011, 04:50 PM   #5
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
For the transmission fluid I was told Pennzoil synchromesh + any friction modifier ...I gues the Lucas tranny fix is recommended?
Old March 15th, 2011, 07:23 PM   #6
Roamin's Avatar
Roamin is on a distinguished road
I would check with Ford to see what they call for. They may have changed their opinion on what it needs like they did with the T-3650.
Change your fuel filter!
I would assume that Lucas tranny fix would be for a transmission that needs fixin. Does yours? We all know how well mechanic in a bottle works.
2004 GT KB 2.1L
Old March 15th, 2011, 11:29 PM   #7
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
I have a t-56 and I was going to use a friction modifier in it. idk about that tranny fix someone else mentioned it.
And good call on the fuel filter i'll add that, thanks
Old March 16th, 2011, 03:06 PM   #8
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
u can even go as far as changine ur rear diff oil, changin ur pcv valve, cleaning your maf, cleaning your iac, cleaning your throttle body, and yea like stated above your fuel filter
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/208515-doing-some-routine-maintenance-soon-suggestions.html
Thread Doing some Routine Maintenance soon, suggestions? | Forums at Modded Mustangs | BoardReader This thread Refback June 14th, 2011 01:39 AM
Threads Similar to: Doing some Routine Maintenance soon, suggestions?
Routine maintenance schoff 99-04 4 October 26th, 2010 04:08 PM
Routine maintenance schoff General Car Care & Detailing 4 October 26th, 2010 05:06 AM
routine maintenance OHHitsKB 2005 - 2010 V6 9 October 5th, 2010 08:40 AM
Routine maintenance...I know, I know, just help a brother out. freefallin2000 99-04 35 June 3rd, 2010 10:33 AM
routine maintenance GTsetGO Modular Mustangs 5 January 31st, 2007 10:36 PM
