Code P1519??
LinkBack (1) Thread Tools
Old April 20th, 2011, 07:41 PM   1 links from elsewhere to this Post. Click to view. #1
Wich88's Avatar
1997 SVT Cobra
Wich88 is on a distinguished road
Code P1519??
So I hooked up my diagnostic tool on my car today and it pulled up P1519. It says intake manifold runner stuck closed ( bank 1 ). I was wondering if I could get some input on this and how it affects the performance of my car. I've only had the car a couple of months and no check engine light has come on. So I'm assuming its had this problem since I've bought it.
MM Cobra member #89
MGW Shifter, 3.73's, Moser axles,UPR upper and lower control arms, MSD COILS, Flowmasters 40's, Cobra R's wrapped with Nitto's,
Old April 24th, 2011, 08:17 PM   #2
97 cobra
Keasbey is on a distinguished road
imrc's stuck. you can toggle it from behind the block, each side has a throttle like cable running to it. that really wont fix it but it should temp help open and close it.
do a google search on IMRC cleaning, basically take off the upper and lower intake and clean away. you can seafoam it but if youre throwing a code id say you are beyond that.
Old April 24th, 2011, 09:22 PM   #3
Wich88's Avatar
1997 SVT Cobra
So the runners are actually in the intake? It says the one is stuck closed, took the car out today and it pulls good through the rpms.I would think if the one is closed, it wouldn't pull in the higher rpms. Right?
MM Cobra member #89
Old April 24th, 2011, 09:41 PM   #4
Wich88's Avatar
1997 SVT Cobra
Figured I would post a link on how to clean IMRC, so if anyone else runs across this problem.
How to: Clean IMRCs (part-1) - MustangForums.com
MM Cobra member #89
Old April 25th, 2011, 12:01 PM   #5
97 cobra
Upper intake off
https://fbcdn-sphotos-a.akamaihd.net..._6253580_n.jpg
Lower intake , fuel rail
https://fbcdn-sphotos-a.akamaihd.net..._4865997_n.jpg
IMRC/controller and fuel rail
https://fbcdn-sphotos-a.akamaihd.net..._7508662_n.jpg
IMRC's mine werent throwing a code but i just wanted to clean them, this is after 2 seafoaming withing 4 months
https://fbcdn-sphotos-a.akamaihd.net..._1364119_n.jpg
Cleaned up
https://fbcdn-sphotos-a.akamaihd.net..._4049757_n.jpg
they sit right under the lower intake between the block and the intake
Old April 25th, 2011, 12:23 PM   #6
Wich88's Avatar
1997 SVT Cobra
Thanks! I don't think I'm going to bother with the seafoam since I have 88k on the car. Good time just to take it all off and give it a good cleaning, maybe do a little painting on intake and TB while I'm at it.
MM Cobra member #89
Old April 26th, 2011, 01:14 PM   #7
Wich88's Avatar
1997 SVT Cobra
Well, just started taking the intake off to clean the runners.
MM Cobra member #89
Old April 27th, 2011, 12:12 PM   #8
Wich88's Avatar
1997 SVT Cobra
Does anyone recommend doing the IMRC delete?
MM Cobra member #89
Old April 27th, 2011, 12:58 PM   #9
97 cobra
i did it just because i went with a supercharger and didnt want to hinder my airflow or want then stuck when i was throwing a ton of air at it. my understand is it will help top end but make the low end a little more sluggish and require a tune to help make up for that sluggishness
Old April 27th, 2011, 01:13 PM   #10
Wich88's Avatar
1997 SVT Cobra
That's what I read, you have to increase your timing to make up for the loss in the low RPM's. I think I'll hold off on doing the delete. What about porting and polishing the intake?
MM Cobra member #89
Old April 27th, 2011, 10:49 PM   #11
97 cobra
now were beyond my info, my understanding is most go with a short runner intake mod but i hear this is only good for n/a applications mostly
http://home.flash.net/~ivc1/cobra/manifold.html
fun website that i wish was more... 2011
Old April 28th, 2011, 06:32 AM   #12
Wich88's Avatar
1997 SVT Cobra
After all i've read i'm still kinda undecided whether or not to do the delete. I just want to know how my car will act cruising around at low rpm. Need some people to chime in that have done it. My engine is stock and I don't plan on putting a blower on it anytime soon.
MM Cobra member #89
Old May 3rd, 2011, 03:06 PM   #13
Wich88's Avatar
1997 SVT Cobra
Decided to keep the runners in. This how it turned out after cleaning.
MM Cobra member #89
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/214766-code-p1519.html
Thread fault code p1519 | VWAUDI Forum | BoardReader This thread Refback February 20th, 2012 03:46 AM
Threads Similar to: Code P1519??
DISCOUNT CODE DELETED - New Code Available - Please Read! AMNick American Muscle 86 May 14th, 2012 08:22 PM
How to Fix Airbag Code and EGR Code ModMustang97GT 96-98 2 April 10th, 2011 10:17 PM
SES light-code P1401 code-& DPFE sensor ?'s PacificMustang01 V6 Mustangs 6 May 18th, 2010 02:39 PM
Code Mustang RacR94 99-04 6 December 19th, 2007 10:40 PM
DCT code shamntgmry 99-04 12 August 18th, 2007 04:47 PM
