98 cobra build
Old April 23rd, 2011, 05:36 PM   #1
98 cobra motor on 98 GT
c-zar is on a distinguished road
98 cobra build
Next week I'm taking my teksid block to the machine shop, i think it will be bored .020 over. I've been looking for complete rotating assemblies and the price is really close to the price of a complete short block, the only difference is that i wont get an aluminum block. I'm planning to go f/i next year, nothing more than 450 hp.
Would you guys go with a forged short block or reuse the aluminum block and throw all forged internals?
Is probe industries any good?
Where can I find a complete engine gasket set?
Also, the engine is going in with long tube headers, I've heard that the egr tube has to be modified. What kind of modification is needed?
Thanks
Old April 24th, 2011, 11:23 PM   #2
92Notch's Avatar
1996 Cobra
Not fast enough.
92Notch is on a distinguished road
If you're looking for only 450hp why would you want to use another block? I'm pretty sure both the teksid and WAP blocks are good for a bit more than that. Also, I've heard good things about Probe, also check out DSS Racing =D
Mods: Full 01 Cobra drivetrain (Teksid block ) T56, 3.73s, Pro 5.0, Aluminum driveshaft, JLT CAI, BBK O/R X, SLP LM1s, Full welded in sub frame connectors
Old April 25th, 2011, 01:17 AM   #3
I was just thinking in the cost effect, the short block has warranty but the probe kit is 1100 cheaper than the short block.
I'll check DSS, thanks.
Old April 25th, 2011, 01:52 AM   #4
mfj
2001 Cobra
mfj is an unknown quantity at this point
I am running Probe pistons and I have already made 785 rwhp and will be over 800rwhp once my fuel system is finished. Good stuff.
2001 Cobra- Stroked/Poked/Cammed/Blown
1996 Cobra- CF Clutch/STS/Lowered/CAI- otherwise stock... The daily driver...
[SIZE="5"][B][COLOR="Blue"]MM Cobra Club #3.4[/COLOR][/B][/SIZE]
[SIGPIC][/SIGPIC]
Old April 25th, 2011, 06:00 AM   #5
majorownage is on a distinguished road
Thanks
Number one: Do NOT bore .020 over
For internals: Stock crank, used cobra rods or some probes, cp pistons
If you are doing headers, get the best: Kooks or American racing. The rest is are very marginal at best.
heads: Serdi valve job at the least.
Intake: SSR intake (talk to na_svt if you dont want to do it yourself)
block: make sure to align hone, and make sure they have a torque plate for a modular sized engine. The aluminum blocks are very finicky to clearances, and I advise you to pick up a book on modulars before you send your block out.
1998 Gt full pi swap -Dead and gone
1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver
1998 BAB Cobra-Project
Old April 25th, 2011, 06:33 PM   #6
I was told that it can be bored .020 over. And I cant reuse my cranks since #7 rod bearing spun.
Old April 25th, 2011, 06:52 PM   #7
You don't want to.
Decide what you are doing with the engine and buy parts before waisting money at the machine shop. Been there, done that.
Old April 27th, 2011, 04:45 PM   #8
The block does not need to be bored, so everything is staying at std, I'm going to buy a complete kit from probe industries, crank, rods, pistons, bearings and rings. I feel a lot comfortable knowing that it's staying in std.
Does somebody know where to get a complete gasket set. Modmax has it for $460.
Are the headbolts, main bolts and rod bolts reusable?
Old April 27th, 2011, 07:20 PM   #9
cobra99svt's Avatar
99 Cobra / 96 GT vert.
N/A
cobra99svt is on a distinguished road
Why would you not want to bore .020 over. Isn't that usually a safe bore for these motors? Please explain why this shouldn't be done, becauase I am looking into rebuilding my engine and do forged internals. The mechanic said I should bore .020 over as well. Thanks.
Old April 27th, 2011, 09:45 PM   #10
Bore deflection @ high boost/hp levels
max you want to go overbore is .006ish
Old April 27th, 2011, 09:50 PM   #11
Why not just get your crank turned?
Non of the above bolts are reusable. I *believe* the jacking screws on 98 and earlier cobras are reusable.
Old April 28th, 2011, 04:20 PM   #12
4v Know-it-all
na svt is on a distinguished road
A .020" overbore is very safe, I know someone making over 1000rwhp with a .020" over teksid.
Old April 29th, 2011, 01:13 AM   #13
^^^ I'm going to side with John Mihovetz. But that is all I will say.
Old April 29th, 2011, 01:55 AM   #14
mfj
2001 Cobra
Apples to oranges. Mihovetz runs 60 lbs of boost in his engines...
[SIGPIC][/SIGPIC]
Old April 29th, 2011, 05:55 AM   #15
4v Know-it-all
I can't agree more. If the boost is under 25lbs a .020" will be fine.
Old April 29th, 2011, 02:25 PM   #16
mfj
2001 Cobra
Also keep in mind that Mihovetz is spinning his engine over 9000 rpms lol
[SIGPIC][/SIGPIC]
Old April 29th, 2011, 10:10 PM   #17
cobra99svt's Avatar
N/A
So on a low boost engine, a .020 over bore will be fine then, right?
Old April 29th, 2011, 11:25 PM   #18
4v Know-it-all
Yes, more than safe. It's good for 20psi.
Old April 30th, 2011, 06:13 AM   #19
mfj
2001 Cobra
^personally, I'd even say even up to 30 psi would be totally fine...
[SIGPIC][/SIGPIC]
Threads Similar to: 98 cobra build
LAkingcobra10's 96' cobra build LAkingcobra10 Projects 14 June 2nd, 2011 08:46 PM
Cobra build mustangmanv6@yahoo.com 4V / SVT 3 April 19th, 2010 04:58 PM
engine...cobra or build? energiesource 99-04 57 July 15th, 2009 12:32 AM
TT Cobra Build Comp JonnyB Videos 4 May 1st, 2009 04:03 PM
Cobra build # 01silversnake 99-04 16 October 5th, 2007 08:38 PM
