97 Cobra Tick
Old May 2nd, 2011, 01:25 PM   #1
Look Ma! My First Post!
GLoweCobra is on a distinguished road
Question
97 Cobra Tick
1997 Cobra 44,000 miles
Recently, My Cobra has started to tick in the 2000 RPM range, Sometimes a little lower than that, and sometimes a little higher.
Video:
Around 14 seconds, the audio makes the tick sound rolling, but that isn't how it sounds by ear, just a heads up. The sound between 9 and 13 seconds is almost exactly how I hear it.
It only ticks:
-In gear and under load (it does not tick if I sit in neutral and SLOWLY rev it up)
-When the engine is WARM
-Loudest in 1st Gear
-Does not SEEM to increase in frequency as RPMS increase, although this might just be me, since it only happens between 2000 and 3000 RPMS
ON a side note, I have had high idle and hanging RPMS for over a month now. Don't know if it is related. The ticking started about a MONTH AFTER the idling issues showed up.
Changed IAC, TPS, Charcoal cannister purge solenoid and sensor (was getting a trouble code, trouble code is now gone) Reset idle several times with battery disconnects overnight, push in clutch and it hovers around 1500, then slowly falling in stages to 1000 as i come to a stop.
If I disconnect the IAC while the car is running, the car idles at almost exactly 750.
Old May 2nd, 2011, 04:59 PM   #2
mfj
2001 Cobra
mfj is an unknown quantity at this point
Possible throwout bearing problem?
2001 Cobra- Stroked/Poked/Cammed/Blown
1996 Cobra- CF Clutch/STS/Lowered/CAI- otherwise stock... The daily driver...
[SIZE="5"][B][COLOR="Blue"]MM Cobra Club #3.4[/COLOR][/B][/SIZE]
[SIGPIC][/SIGPIC]
Threads Similar to: 97 Cobra Tick
Before I buy a 96 Cobra...Help (tick) crash13 4V / SVT 3 December 15th, 2010 01:30 PM
Valves....Tickity tick tick tickers tick....how much is too much?? Bottle Fed GT 2005 - 2010 17 November 9th, 2010 07:12 AM
tick tick tick tick tick flattusmaximus78 5.0 Mustangs 20 March 2nd, 2010 11:29 PM
iam the bomb like tick tick SoC@L MuST@ng dRivER The Clubhouse 7 November 1st, 2008 03:07 AM
tick tick boom dude496 99-04 19 May 27th, 2007 03:57 PM
