Pump for 60# injectors
Old May 9th, 2011, 01:28 PM   #1
Fred E. Krugar is on a distinguished road
I have a 96 cobra that will soon have a turbo installed. I do like to go a little overkill for safety reasons. So the question is what pump do I need to be able to push 60# injectors successfully. Also would it be better to just run adjustable fuel pressure regulator over an FMU. All suggestions would be appreciated.
Old May 9th, 2011, 02:10 PM   #2
mfj
2001 Cobra
mfj is an unknown quantity at this point
What are you hp goals... In my opinion, go return style and get an aeromotive boost referenced FPR.
2001 Cobra- Stroked/Poked/Cammed/Blown
1996 Cobra- CF Clutch/STS/Lowered/CAI- otherwise stock... The daily driver...
[SIZE="5"][B][COLOR="Blue"]MM Cobra Club #3.4[/COLOR][/B][/SIZE]
[SIGPIC][/SIGPIC]
Old May 9th, 2011, 02:11 PM   #3
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
aren't 96 cobras already return?
Old May 9th, 2011, 02:20 PM   #4
mfj
2001 Cobra
I have no clue lol. I assumed they were returnless because my 01 was returnless, so my bad. If so, I guess my DD is return lol
[SIGPIC][/SIGPIC]
Old May 9th, 2011, 02:24 PM   #5
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
I think 99+ was returnless. Prior to that it should be return style.
Which brings me to a point; how hard to do you think it'd be to swap in a fuel setup from a pre 99 car, and run big power return style?
Also I'm planning to go with 60lb/hr injectors with twin GT pumps, Cobra tank, and dual FPDM. Pump size also depends on power levels. I'm shooting for ~550hp initially, then eventually 600-700. But keep in mind that's returnless. If you're return you can look at Aeromotive or Walboro, and dual either 255's or 340's.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old May 9th, 2011, 06:38 PM   #6
wildcardfox is on a distinguished road
Ive done the fore fuel hat with twin walbro 255lph in a return setup, then to a Glenns which was later swapped over in favor of the behind bars race cars aluminum tank with twin Bosch 044s and a magnaflow regulator.
My advice if your want to go big (returnless) is to get a sumped tank with either inline pumps or a large pump like the magnaflow or some other brand.
Accufab 4.6L 32 Valve Motor built by John Mihovetz. BTI custom flip hood, Brembo 8/Brembo 4 f:15" r:14.4", BTI Mega Godzilla Intercooler, Turbonetics Super T-76 from Accufab's 6.25 second Race car
Old May 9th, 2011, 11:01 PM   #7
98Cobra_sleeper's Avatar
1998 mustang cobra
98Cobra_sleeper is on a distinguished road
I have a 98 cobra and i sumped my tank, used an Aeromotive eliminator, and an aeromotive adj fuel pressure regulator. Im feeding 72# injectors just fine.
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup)
comin soon...ON3 turbo kit, PTE7175
Old May 10th, 2011, 01:30 AM   #8
So what is the volume of that pump and at what pressure should I run the injectors at? Should I run them at 60# at all times or what.
Old May 10th, 2011, 08:48 AM   #9
MM's king of Neon's
404 - car not found
17.81@87
I can't tell you what pressure or flow rating of the pump, but you don't personally set the flow rate of the injectors. Their duty cycle is based on the fuel map in the ECM, which is set by the tune. It also varies according to load.
You also realize that bigger injectors don't mean more power right? Combustion is a stoichiometric process, and to get more power you need not only more fuel but more air. And unless you're running a turbo or supercharger, you won't have enough air to justify 60's. It's not like switching to bigger jets on a carburetor. Just thought I'd point that out before you spend any money.
Old May 10th, 2011, 11:41 AM   #10
lol yes i do understand that. I am just saying while I am running boost what should my fuel pressure be set at. Or should I just run an fmu with the aforementioned pump?
Old May 10th, 2011, 11:47 AM   #11
mfj
2001 Cobra
Mine is set at 45psi, but it is boost referenced, so for every pound of boost, it goes up 1 psi. So if I'm running 20 lbs of boost, my fuel pressure is 65psi.
[SIGPIC][/SIGPIC]
Old May 10th, 2011, 11:47 AM   #12
MM's king of Neon's
404 - car not found
17.81@87
Ah. I thought when you said "60#" you were referring to 60 lb/hr, as in a flow rate, and you meant 60 psi, as in a pressure. Gotcha. I'm an engineer man, and if there's every anything they drilled into our heads it's PUT UNITS ON EVERYTHING! lol
As for regulator settings you'll have to find someone who runs return style. I've got 0 experience with return style on mod motors. Haven't messed with it since my 1970 Cutlass.
Old May 10th, 2011, 01:02 PM   #13
ok that is what I was wanting so where I might find this regulator. Show me links to what you have plz.
Old May 10th, 2011, 01:11 PM   #14
Ah.I'm an engineer man, and if there's every anything they drilled into our heads it's PUT UNITS ON EVERYTHING! lol
I too am an engineer but I have had several disputes with the professors about it also. If we are in the middle of a conversation the professor should have enough common sense to know what I am referring to.
I am not referring to you but this is just a bad habit of mine, that everybody should be able to read my mind
Old May 10th, 2011, 01:28 PM   #15
mfj
2001 Cobra
You need this sucker right here:
Aeromotive A1000 Fuel Pressure Regulator - Modern Automotive Performance
[SIGPIC][/SIGPIC]
Old May 10th, 2011, 10:47 PM   #16
Thanks for the input.
Old May 10th, 2011, 10:55 PM   #17
Ok for the next question will a 255 lph intank and a 255 inline pump work ok or can the single fuel not handle the full flow of the two? Or should I do something different? Is it possible for me to just fabricate another pickup (gravity fead line from the tank to the inline). What do you guys think? I do aprieciate all the responses thus far.
Threads Similar to: Pump for 60# injectors
Stock pump/injectors poranksta 99-04 3 January 11th, 2011 06:48 PM
Fuel Injectors & Pump Scholl V6 Mustangs 16 August 6th, 2010 01:24 AM
24 lbs injectors and a fuel pump... b-on-b 5.0 5.0 Mustangs 7 October 21st, 2008 10:24 AM
Fuel Pump And Injectors imported_Gt_Jay 5.0 Mustangs 14 December 10th, 2007 10:14 AM
Injectors and Fuel Pump scxc15 V6 Mustangs 2 November 3rd, 2007 02:48 PM
