cam journal repair
Old May 12th, 2011, 08:23 AM   #1
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
cam journal repair
is MP the only place that repairs cam journals on these things? i have had him do 3, does damn good job, but just checking to see if there was anyone else that did it. this mach decided to break a secondary chain , the first intake cam journal is ate up, and i need to send cam out to see if it can be saved. amazingly that seems to be the only damage (visually). usually i see bent valves, busted cam towers, followers fallen off, etc.
i will start on his psr today or tomorrow as well, hopefully i have it done by time the head returns. then we can finally put the thing on the dyno and tune it
Old May 12th, 2011, 08:46 AM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Doesn't Houston Performance do them as well? We checked on it when mine went south.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old May 12th, 2011, 08:51 AM   #3
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
eh, not too sure about them man. too many good and bad out of them.
Old May 12th, 2011, 02:46 PM   #4
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
I can't think of any other place that does repairs. As you already know MMR sends their work out. Al Papitto might do repairs, but I doubt he is faster and/or cheaper than MP.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Threads Similar to: cam journal repair
4.6 Cobra crank journal specs Travstang 4V / SVT 4 April 1st, 2011 01:15 AM
Wall Street Journal Sleeper_Stang_89 The Clubhouse 9 October 3rd, 2009 08:47 AM
A/C Repair ??? yeewiz General Tech 0 December 8th, 2008 06:17 PM
$1,200 AC repair? hardhitter 99-04 20 February 23rd, 2008 07:43 PM
Do it your self A/C repair Roadhawg The Clubhouse 2 July 29th, 2006 07:26 PM
