Please ignore my ignorance...
Old May 16th, 2011, 06:02 PM   #1
Captain Opinionated!
HurrycaneStang's Avatar
01' Cobra Vert
When life throws you a curve, downshift and take it vigorously.
HurrycaneStang is a jewel in the roughHurrycaneStang is a jewel in the roughHurrycaneStang is a jewel in the rough
Send a message via Yahoo to HurrycaneStang
Im not too keen when it comes to heads and their parts, is a valve guide the same thing as a lash adjuster? I google imaged both and they look exactly the same. Im starting to think the noise or "rattle" I hear from 3000 to 4000 RPM's when at cruising speed is either or, but oddly enough I dont hear it when throttling through at a quick pace...thanks!!!
MM Cobra Club #100
Old May 16th, 2011, 06:05 PM   #2
01' Cobra Vert
Im starting to notice they are different and have different purposes lol, so any idea which might be the culprit?
MM Cobra Club #100
Old May 16th, 2011, 09:13 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
guides are powdered medal stock or aftermarket bronze. this is what holds the valve and tolerences are crucial in life of the valve. lash adjuster is little black cylinder thing with adjustable piston. it is on the other side of the follower.
as for your noise, if it were an adjuster, the noise would generally be there all the time no matter if you at idle or WOT.
Old May 16th, 2011, 11:08 PM   #4
01' Cobra Vert
yeah, I got a chance to pop the hood today when I got home and listen to it, its kinda odd, it doesnt make any more noise than most 4.6L do when revving it up in the driveway, but when i took it around the block I can hear it again between 3000-4000RPM, im starting to wonder it has something to do with the drivetrain? The guy supposedly put in an aftermarket clutch/flywheel right before I bought it and it has an aftermarket short throw in it as well...
MM Cobra Club #100
Old May 17th, 2011, 12:16 PM   #5
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Maybe a throw out bearing. Press the clutch in and rev it up to 3-4k. Does it go away?
Old May 17th, 2011, 01:03 PM   #6
01' Cobra Vert
yes ... well a lot more than if im in gear...
MM Cobra Club #100
Old May 17th, 2011, 03:08 PM   #7
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
So the sound goes away with the clutch pushed in?
Old May 17th, 2011, 04:37 PM   #8
01' Cobra Vert
I dont hear it unless im in any gear and between 3-4K RPMS and at cruising speeds, but if im in neutral and rev it up there I dont hear it, also if im in gear and with heavier throttle through it I dont hear it as well, sorry, I dont know how to word it exactly lol
MM Cobra Club #100
Old May 17th, 2011, 05:15 PM   #9
01' Cobra Vert
So researching a lil more into it, I found out alot of people suffer from "shifter noise" whether it be from the aftermarket hurst shifter or my Steeda Tri-ax shifter, I found a link to this guy that makes shifter gaskets and it supposedly cuts out like 95% of noise, im really hoping this is the issue, im gonna pull the boot today and listen to it, does anybody else have shifter noise?
MM Cobra Club #100
Old May 17th, 2011, 07:13 PM   #10
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Cobra Bob's gaskets? lol, from SVTP...
Old May 17th, 2011, 11:13 PM   #11
01' Cobra Vert
Lol yeah, its only 10 bucks so we'll give it go and see how it turns out
MM Cobra Club #100
Old May 18th, 2011, 08:55 AM   #12
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
It's a good product.
Old May 18th, 2011, 10:42 AM   #13
01' Cobra Vert
Im gonna look through the forums and see if i can find somebody that bought them and made a thread on them, im crossing my fingers that this gets rid of the noise
MM Cobra Club #100
Old May 18th, 2011, 01:43 PM   #14
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
It's cheap. It doesn't hurt to buy it anyways...
Old May 18th, 2011, 10:49 PM   #15
01' Cobra Vert
Well Friends, Im really hoping its just my shifter rattling, but unfortunatley preparing for the worst, it might be a spun rod bearing I found this video and it sounds almost indentical to my issues, and it happens at 3000 RPM's only....fuck my life, at least I have a spare Mark VIII motor lying in my garage maybe I can reuse some of its parts or use what I get from selling my 98GT and just buy forged internals....
MM Cobra Club #100
Old May 19th, 2011, 05:53 AM   #16
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about
can you post the video? Im curious
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
MM Cobra Club Member #61
Old May 19th, 2011, 10:21 AM   #17
01' Cobra Vert
MM Cobra Club #100
Old May 19th, 2011, 10:25 AM   #18
01' Cobra Vert
the only thing different is, you dont hear mine until 3K
MM Cobra Club #100
Old May 19th, 2011, 09:32 PM   #19
01' Cobra Vert
Okay so I got a video of my actual car, its kinda hard to hear unless your volume is up high, so maybe the noise is originating near the shifter? If it isnt good enough sound quality let me know and ill re-do it, thanks guys
MM Cobra Club #100
Old May 19th, 2011, 09:39 PM   #20
04GTAMPA's Avatar
2001 Mustang SVT Cobra
04GTAMPA will become famous soon enough
I want to rule out the spun bearing. Does it change when the engine is at different temperatures? How's your oil level?
Do you feel it in the shifter? Try to feel it by the feeling the noise to a "tap" on a rhythm pattern in the shifter.
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
Threads Similar to: Please ignore my ignorance...
Ignorance GTman05 The Clubhouse 48 April 12th, 2011 10:30 PM
Forgive me for my ignorance 89Bullitt 2.3 Mustangs 7 September 22nd, 2010 01:57 PM
Ignorance wannabeimportkiller The Clubhouse 20 December 21st, 2009 08:55 PM
The ignorance of people Cricket The Clubhouse 12 November 5th, 2008 10:53 PM
excuse the ignorance.. BWAL 2005 - 2010 11 December 2nd, 2006 07:11 AM
