Lash Adjuster for Cam Degreeing?
Old May 20th, 2011, 01:34 PM   #1
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Where does everyone usually get their adjustable solid lash adjusters for cam degreeing? I see modular head shop has a kit for about $70, I know MMR sells one too, among a few other places.
Edit: Just did some research on MMR, only $30, but mixed reviews.
Basically, which one does everyone use/reccommend?
...as I sit here waiting for my damn Ford 4v spring compressor to come in. I saved about $80 by going through Tousley Ford, but it's taking some time for it. They also saved me about 60% on cam bolts, so I really can't complain.
Bonus: If you know any good writeups for keeper removal/installation I'm all ears. That is one thing I really do not want to mess up. I also got a new set of them while I was at it as extra insurance.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old May 20th, 2011, 03:00 PM   #2
4v Know-it-all
na svt is on a distinguished road
If you degree using the centerline method you can use a welded adjuster. If you use the .050" open and close method you will need a true adjustable adjuster.
Old May 20th, 2011, 03:07 PM   #3
MM's king of Neon's
404 - car not found
17.81@87
Well I don't need the "true" adjustable lash adjuster, I'm doing it the ICL method like you mentioned. Though the adjustable feature would be nice.
Have you heard anything about the MMR one? I might just go that route.
Also any insight as to lash adjuster re-installation? I know you've got to bleed them out after you remove them, but I assume it would be good to pump them back up before you fire the engine to get back to zero lash. Will priming the oiling system and cranking it a few times take care of that?
Excuse my ignorance. These hur fancy mod motors are a far cry from the old pushrods I've worked on. No having to set lash with feeler gauges is nice though.
Old May 22nd, 2011, 08:19 PM   #4
tbird88tbo's Avatar
1998 Mustang Base Model
tbird88tbo is on a distinguished road
trickflow has a kit. with an adj lash adj. you can get it from summit for cheap.
Threads Similar to: Lash Adjuster for Cam Degreeing?
Clutch Quadrant, Firewall Adjuster, Height Adjuster Install w/pics Serlin General Tech 10 February 25th, 2012 04:00 PM
Lash adjuster removal 463 99-04 6 May 9th, 2011 06:07 PM
cam degreeing mustang_gtr_99 2005 - 2010 13 February 6th, 2011 11:35 PM
wasn't a lash!!!! jdlsstang 99-04 26 April 19th, 2010 08:51 AM
lash adjuster for degreeing ajm 99-04 1 July 14th, 2008 07:41 AM
