Mach 1 lowering springs
Old June 11th, 2011, 11:52 PM   #1
Mach1dmb!'s Avatar
2003 Mustang Mach 1
Mach1dmb! has a spectacular aura aboutMach1dmb! has a spectacular aura about
So I decided the first mods I want to get right away for my new Mach is a short throw and lowering springs. I was thinking H&R super springs...anyone wanna vouch this is a good choice?
Also, do I just need the springs? How difficult is installation?
Old June 12th, 2011, 12:04 AM   #2
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Installation of springs is pretty straight forward. But those springs will require caster/camber plates for a proper alignment.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old June 12th, 2011, 07:30 PM   #3
Mach1dmb!'s Avatar
2003 Mustang Mach 1
Right. Is that all though? I won't need upgraded shock/struts? Just an alignment after I install?
Old June 12th, 2011, 07:41 PM   #4
Who needs titles...
WabashaCobra99's Avatar
1999 Mustang Cobra
WabashaCobra99 is a glorious beacon of lightWabashaCobra99 is a glorious beacon of lightWabashaCobra99 is a glorious beacon of lightWabashaCobra99 is a glorious beacon of lightWabashaCobra99 is a glorious beacon of lightWabashaCobra99 is a glorious beacon of light
You might have trouble getting the stock shocks off the stock CC plates. Mine wouldn't come off and I had to cut the bolts. Just said screw it and upgraded to new shocks and glad I did.
Also changed the ball joints, and added a bump steer kit since I already had it apart. Don't know if this stuff was necessary, but I can bomb over bumps and potholes without getting tossed into oncoming traffic. Guess that's worth it.
http://dakotaboy88.smugmug.com/Cars/Random-Stuff/i-BT8FVJ7/0/O/whitecobrasig.jpg
MM Cobra Club Member #97
Just call me Jon
Minnesota!
Jon's Sig Collection
Old June 12th, 2011, 08:29 PM   #5
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Like Wabasha said they aren't required. Technically CC plates aren't required, but you'll wear your tires out fast.
Old June 13th, 2011, 04:22 PM   #6
maxgst's Avatar
maxgst has a spectacular aura aboutmaxgst has a spectacular aura aboutmaxgst has a spectacular aura about
your stock shocks will die after a while
.............................2000 GT Vert.............................
How To Cut/Remove springs
Old June 19th, 2011, 12:40 PM   #7
Mach1dmb!'s Avatar
2003 Mustang Mach 1
So I'm thinking about going with the springs, MM c/c plates, ball joint, and bump steer. Idk about shocks though...What shocks would be best for a Mach 1?
Old June 19th, 2011, 05:31 PM   #8
03 Mach 1 03 SVT Cobra
76 Cobra 2
76Cobra2 is on a distinguished road
I went bilstein all the way the ws0 struts work great, but they do make your suspension rock hard.
Old June 19th, 2011, 05:46 PM   #9
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
What dampers are best really depends on what you're using the car for.
Bilsteins are the best all-around damper you can buy for a DD, and one of the best for a handling car (they're also what I run, and what I ran on my Cobra). Koni Yellows are probably better for a competitive corner-carver (unless you can afford to get your Bilsteins custom valved...). For a drag shock, you'd have to ask the other guys... I hear Lakewood and Strange Engineering come up fairly often, though.
O o
/¯/______________________
\_\
Threads Similar to: Mach 1 lowering springs
Drag springs or lowering springs??? AggieStang General Tech 10 February 18th, 2012 12:45 PM
stock springs vs lowering springs in drag TotoGT06 2005 - 2010 4 April 14th, 2010 10:25 PM
Mach 1 chin + lowering springs tlr96 96-98 10 January 7th, 2008 07:18 PM
