what would be the best route on my cobra
I have a 96 convert cobra and im wanting more hp and i was going to go with a kenne bell supercharger but the car has 145000 miles on it so i think i need to rebuild it and i would need to rebuild the transmission to. So i was wanting to know if it would be better to rebuild it all and buy a kenne bell or should i just sell the motor and trans and do a 03 04 cobra turn key engine swap motor and trans all together? Cause for me to rebuild my engine and trans and buy a kenne bell it would cost me more to do that than it would for me to just buy a turn key engine swap off ebay... Your input would be greatly appreciated thanks...
2003 Mustang Mach 1
i would just go for the swap and you will still have a forged bottom end and make the same amout of power either way
2003 Mach 1 Oxford White K&N intake, Magnaflow Exhaust |
1997 Mustang Cobra
8.65@84mph
I am in the same boat as you kinda, I only have 95k tho. Im thinking i may rebuild the motor with high compression pisons and head work to see what kind of NA numbers i can get.
97 cobra
dont go with that blower. it doesnt have a intercooler and your just asking for problems unless you really want to add alot of stuff to keep it cooler.
i just got my car back from the dyno. 97 convert cobra, bbk lt and x pipe. imrc deletes. accufab tb, 255 walbro pump, 60# inj, sct maf, procharger d1sc with the 10lb pulley. easily and safely tuned to 433hp 404tq. 90k miles. its alot of fun so far. i plan on forging the internals, upgrading fuel lines and cranking the boost a bit more. but until then ill enjoy the new set of power. everyone praises the 96-98 block for its amazing hp capabilities and being so light. i wouldnt switch to the big one unless the funding is really really tight. |
Threads Similar to: what would be the best route on my cobra
| Route to go when buyin 03/04 Cobra? | JACK MEHOFF | 4V / SVT | 19 | May 14th, 2011 03:34 PM |
| Cheaper route for Cobra pump PPRV delete | 40thAnnivGT | 99-04 | 1 | May 1st, 2011 06:40 PM |
| What route should I go?? | snake_bitten711 | 99-04 | 21 | October 7th, 2010 03:54 AM |
| Going a different route with the car | PapaSmurf | 99-04 | 56 | July 22nd, 2010 11:40 AM |
| Which is the better Route? | 4eva4ord | 96-98 | 8 | June 25th, 2010 10:41 AM |
