01 Cobra
engine help!!!!!
Hi well start off with this is my first time on this.
I have a 2001 cobra. has 130k now have a light rod knock around 2500-3000k rpm. time to upgrade the engine so trying to find out what to go with. trying to see what guys have tried and numbers they got. Thanks. Israel |
#2 | |
www.westendelectric.com 2004 Screaming Yellow Cobra Terminator 2009 GT-500 Shelby 1964 Falcon Sprint,302 roller,cam etc. 2005 SRT-10 Viper Truck 1973 Corvette Stingray 2012 Ford f-350 diesal dually lariot Crew Cab |
01 Cobra
no i was thinking more about rebuilding the bottom end and cams
1999 mustang cobra
![]() iTrader: 1 reviews
Forged rotating assembly and a KB
Black and White Crew Crew Member # 5 Check garage for mods and pics if you Los Angeles and want to ride send me a text (323) 270-6827 0% Wheel hop, 0% broken parts, 100% wheel spin |
2009 Mazda Mazda6
^ +1
-2004 Mustang GT: Sold..Worst mistake of my life. ![]() -2009 Mazda Mazda6 i Touring: The new whip Wish I could've kept the Mustang and the Mazda at the same time... |
Forged goes without saying.... Any power adder other than nitrous- simply because I love having my power always there. Turbo, supercharger: centrifigual or screw type.
Accufab 4.6L 32 Valve Motor built by John Mihovetz. BTI custom flip hood, Brembo 8/Brembo 4 f:15" r:14.4", BTI Mega Godzilla Intercooler, Turbonetics Super T-76 from Accufab's 6.25 second Race car
MM's king of Neon's
404 - car not found
17.81@87
The way I see it, here are your options:
1.) Rebuild. Somewhere between $200-500, depending on how much you do, and how much needs repair. 2.) MKVIII swap. As low as $300-500. You will be going backwards somewhat by switching to B-heads. Cheap and easy though. 3.) C-head engine swap, Aviator, Marauder, Mach 1, or Cobra donor engine. Generally around $1500 or more. 4.) Forge everything while you're in there. At least $2000. Will take considerable skill, but will let you run the power adder of your choice down the line. 5.) Built long/shortblock. All the fun of forged, already put together. Large variation of price here depending on what you get. Expect at least $2500, but it's assembled and forged! I somewhat went this route, but I bought a 2003 Cobra longblock (and then some) for $3500. Certainly not a bad deal. What you get is up to you based on your budget, your skills, and your plan.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
MM's Orangest
2004 Mach 1 Mustang
Forge and rebuild your motor. Then strap on an On3 forward facing turbo kit.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
Threads Similar to: engine help!!!!!
| 03 crown victoria engine vs. 2003 mustang gt engine?? Which tko 500? | 98 Stanga Banga | 99-04 | 8 | September 20th, 2010 08:25 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| Engine install: Life engine up, or drop engine? | trill gear head | 2005 - 2010 | 14 | October 26th, 2009 01:17 AM |
| Washed n cleaned engine today.. pics of engine bay. | MustanG_guy17 | The Clubhouse | 40 | January 4th, 2008 10:14 PM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 05:09 PM |
