1998 Mustang Cobra
Lean Codes?
My O2 sensors fell, and either got wet or got caught on something. Anyway, i cant keep my car running, and it is throwing lean codes. Dont have the codes off of the top of my head, but could hook the SCT back up to pull them again.
Any tips before i start replacing O2 sensors at $63 a pop? connections look fine, and i dont see anything loose.
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner |
#2 | |
MM's king of Neon's
404 - car not found
17.81@87
Hook up the DVM to the O2 sensor circuit, not the heater, read voltage on the 2V setting. In open air (completely lean) it should read 0.0-0.1V Completely immerse the sensors in the flame. All the oxygen is consumed in that flame, so it's completely rich. This should read 0.9-1.0V. It should respond relatively quickly, within a second or so. Of course there's a gray area here, but if they're completely toast, you'll know. It's not a perfect test, but cheaper than $63. Checking continuity from the base of the sensor to the connector doesn't hurt either.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
03 Cobra
![]() iTrader: 1 reviews
P0171 and P0174? Have you checked fuel pressure?
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 |
1998 Mustang Cobra
funny you ask about fuel pressure....I bought a new 02 sensor moved it around. Same problem and the codes didnt return. I will elaborate in a new thread.
Reps for the input
Threads Similar to: Lean Codes?
| System too lean codes | snake_fl | General Tech | 0 | July 23rd, 2010 02:05 PM |
| Pulling codes..too lean | JerseyTrueBlue | 99-04 | 10 | June 21st, 2010 02:32 PM |
| Pulling Lean Codes?? Help Plz. | aluv4speed | 99-04 | 13 | May 27th, 2010 03:27 PM |
| Two more codes, Lean in Bank 1 & 2 | Shaun03GT | 99-04 | 17 | April 11th, 2010 07:07 PM |
| Lean codes | 94blakonblak | 5.0 Mustangs | 2 | July 21st, 2009 01:08 AM |
