Rear Build
Old July 7th, 2011, 10:38 PM   #1
2004 Mach 1
bigtom is on a distinguished road
Send a message via AIM to bigtom
Rear Build
Ok, guys the mach is going into the shop sat. morning. To have the rear built. Im using 31 spline moser axle's eaton detroit tru trac locker. ford racing 4.10's. Trickflow diff. cover and the ford bearing kit m-4210-c but replacing the axle seals that come with it with the motorcraft f67z-1s177-aca and new indicators. ford number f4zz-2c189-a
Old July 9th, 2011, 02:05 AM   #2
jk_aktion's Avatar
jk_aktion will become famous soon enough
is that trickflow cover an axle girdle? that would be a good idea. and don't be alarmed when you hear the truetrac clunk, it's normal and you won't break it. just use the correct gear oil.
Old July 9th, 2011, 12:13 PM   #3
2004 Mach 1
the cover have the bearing cap support studs in it.. and the oil i got is 85-140 what summit told to get and was told not to use synthetic.. and i heard they make noise i was gonna got with the regular locker but heard they make alot of noise and sometimes its dont unlock when you reverse.. thats why i went with the trutrac works as an open and locks.... i just dropped it off at the shop an hr. ago should have it monday or tuesday
Mac o/r H-pipe, mac cat back, jlt ram air intake, promotion tr-3650,
Old July 9th, 2011, 11:54 PM   #4
jk_aktion's Avatar
sounds good man, good luck!
Old July 10th, 2011, 02:12 PM   #5
2004 Mach 1
thanks dude..
Threads Similar to: Rear Build
Cheapest way to build rear end? maxgst 99-04 34 May 7th, 2011 01:51 AM
Rear Build bigtom 4V / SVT 29 February 6th, 2011 03:53 PM
rear end build and suspension AndrewA. 99-04 26 March 28th, 2010 04:49 PM
Rear end build sniperd 5.0 Mustangs 17 May 22nd, 2009 08:19 PM
Ok guys need help w/ rear end build bloo4.6 99-04 9 April 23rd, 2007 02:59 PM
