Cobra bogs down while throttling thru corners... - Page 2
LinkBack (1) Thread Tools
Old July 14th, 2011, 01:17 PM   #21
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Originally Posted by sikedsyko View Post
The way traction control works in our cars, is with speed sensors on the rear wheels. If it detects a wheel slipping, it just slams on the rear brakes.
Are you sure on that? Jamming on the rear brakes mid-slide is going to make the car slide more, not less. It'd be like ripping the e-brake mid-turn.
O o
/¯/______________________
\_\
Old July 14th, 2011, 02:12 PM   #22
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
lol well thats what I had heard. I don't think it just slams on the brakes though, I'm pretty sure it just brakes the tire thats slipping.
edit: Did some research and apparently it cuts power and brakes the slipping tire.
The traction control system for the Mustang that combines brake and engine management to control wheelspin. When any of the four ABS/traction control sensors detect that a drive wheel is spinning at a rate higher than its counterpart, ignition spark is retarded and the fuel/air ratio is modulated to attenuate torque delivered to the slipping tire. If the condition persists, cylinder cut-off occurs, brakes are applied to the wheel with low friction, and power is transferred to the other drive wheel. The driver is informed of TCS events via an indicator light in the instrument cluster. TCS may not significantly improve traction when both wheels are on a slippery surface, but it optimizes the use of available traction. The benefit under this condition is improved vehicle steerability and stability provided by controlling excess wheel slip.
MM Cobra Club #66
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/225512-cobra-bogs-down-while-throttling-thru-corners.html
Stuffed Cobra This thread Refback July 12th, 2011 12:33 AM
Threads Similar to: Cobra bogs down while throttling thru corners...
my car bogs down at WOT but not 1/4 throttle??? Broke4.6 99-04 24 December 20th, 2010 06:56 AM
clear corners or smoked corners? blackGTstang 2005 - 2010 12 August 16th, 2010 04:06 PM
anyone running cobra euro clear corners tfofkyle 96-98 15 January 7th, 2010 07:44 PM
car bogs when its reved CobraStang161 4V / SVT 6 July 31st, 2009 05:52 PM
amber corners or clear corners Badasstang281 99-04 5 February 11th, 2007 05:02 AM
