2001 Mustang GT
![]() iTrader: 2 reviews
Mach 1 hesitation
My Mach has like a hesitation at 1-2000 rpms past that its fine. Does almost feel like a misfire but no check engine light at all. I have done the fuel filter and spark plugs already but still no help. I believe its sensor related.
bbk longtubes, bassani x, borla stingers, AM intake,bbk throttle body, Under drive pullies,Zex wet 125hp kit SCT Tuned by bama and drag radials, drag springs, agx shocks, lower control arms, subframe connectors MM+Cleavage Club #26 |
2001 Mustang GT
Any ideas. Im.gonna clean the maf tonight, the iac and then after its the pcm which may need to be recalibrated?
03 Cobra
![]() iTrader: 1 reviews
You have any way of testing the throttle position sensor to see if its dropping out? You could just probe for dc voltage at the center wire of the sensor with key on engine off and slowly increase the throttle by hand looking for the voltage to drop out.
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 |
2001 Mustang GT
I just swapped a tps from another motor I had in my garage. Didn't fix it. Here is where the issue I believe is. While datalogging, the exact rpm range with the issue is shows a very low spark count. Could this be the coils. There was oil on them wwhen I checked. Valve cover gasket time and coils I will do next
1991 ford mustang lx 5.0
12.1@114
sounds like maybe time to change some coil packs.. buy a new one and swap it around until you can find which cylinder it is.. mine did this and i just changed all of them and solved the problem.. could be wrong but sounds like similar trouble i experienced
![]() 91 5.0 lx
03 Cobra
I have a similar problem with mine but hoping its just a tuning issue cause it didnt start till after the blower. It hesitates just off of idle on accel then comes right out of it.
KB'd GT
post up a datalog of the issue.
2001 Mustang GT
Thanks guys. I believe its the coil packs they had oil on them. Need to do valve cover gaskets then cop. Ill post a datalong tonight.
Threads Similar to: Mach 1 hesitation
| hesitation | ricardov88 | 96-98 | 3 | February 8th, 2011 09:22 PM |
| hesitation | riddlee josh | V6 Mustangs | 8 | April 19th, 2010 05:26 PM |
| help with my hesitation | mypony | 96-98 | 9 | October 17th, 2009 03:54 PM |
| hesitation? | CBSTANG | 99-04 | 5 | July 26th, 2007 07:57 PM |
| hesitation | usmcsawgunner | 5.0 Mustangs | 9 | July 10th, 2007 08:58 PM |
