2011 Mustang V6
Which to pickup Cobra Or Mach?
I've been looking into getting either a New Edge Cobra or Mach1, 01-04 Cobra or the 03/04 Mach. Besides the obvious advantages of an 03/04 Cobra with the S/c and their disadvantage of a 20K+ price tag, what are the pros and Cons between the two. Engines potential, rear ends, person opinions. Id really like an 04 Cobra but the reason I'm trading is to "Try" to avoid the 20k monthly payments. Any help would be much appreciated!!!!
MODS: BBK Chrome Long Tube Headers and X pipe| Pypes M80 Mid Mounted Muffs(Dumped)| JLT Carbon Fiber CAI| SCT Tuner 93S/P/R --> 290RWHP/270RWTQ(DYNOJET) Wheels 18x9 Black Saleens 255/45/18 Sumitomos(Fr) 18x10 Black Saleens 275/40/18 Sumitomos(Bk) |
2003 gt
5.4 32v on the way
if the 03/04 cobra cant be had within a comfortable monthly payment id say go for the mach.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
Priest of the Car Gods
Depends on your goal for the car.
In general, if you're more into straight-line racing, you'll be happier with the Mach 1 than a '99/01 Cobra. If you prefer automatics, you can find that in a Mach 1s; all Cobras are manual tranny only. The con to that though is that automatic-equipped Mach 1s didn't get the forged crank that manual tranny cars did. If you're into cruising and/or corner-carving, you'll be happier with the Cobra, and I'd dare say happier with an N/A Cobra over the Termie (due to being about 200 lbs lighter and better balanced).
#4 | |
2011 Mustang V6
2009 ROTY
400rwhp is a pulley away on a 03/04 cobra. otherwise, i think the rev has it all nailed. my call would be to find a terminator with a solid axle, or to find one and add it in. then its the best of both worlds imo.
Terminator motors have a lot of potential, but stock they're already at the power level you're looking for. N/A 4vs can be built, but it's not cheap (cam sets are ~$1k) and there's really not that much in the way of aftermarket for them (for instance, there are no aftermarket 4v heads, and the only aftermarket intakes are sheet metal).
Curious why you wouldn't use the '11 as the DD. It's gonna be a better handler, more comfy, and get better mileage than a 4v ever thought of.
#7 | |
2011 Mustang V6
Wyatt's #1 Slut
N/A
If you can afford it termi. If not mach1 cause they are sexy as hell!
2003 gt
5.4 32v on the way
if you are only looking for 400hp go for the mach and run a little bit of boost. If you wanted 600+ it would be better to start with the 03/04 cobra but at 400hp you are still ok with the stock bottom end of the mach. The 99-01 cobras are nice, but the mach is nicer.
MM's Orangest
2004 Mach 1 Mustang
Get a GT and throw a supercharger on it. You'll have 400hp and it would be about the cost of a Mach or even a little cheaper.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
1998 Mustang Cobra
im not going to insert my opinion, cause i haven't driven either and think both have advantages....Here is a 03 cobra in OKC for 18k, could possible be had for cheaper.
2003 Mustang cobra for sale or trade
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
stock is always better than modified. if your looking to have 400 hp then get the 03-04 cobra. it is built all the way around to handle the power. mach 1's are nice but the 3650 trans sucks compaired to the t56. even though the t56 comes stock with a 10 spline input shaft it can be upgraded easily to 26 spline for a fraction of the cost to have a 3650 built to handle hard driving of 400 tq and up. cobra's have a much better fuel system that can support about 500 hp with out any changes, and with a bap installed it can support 600 rwhp. not to mention the tank is baffled. as for the motor. a modified mach 1 or 99-04 cobra with 450 rwhp may hold up or it may not, its a crap shot. a 03-04 cobra motor will stand a better chance of being mantanance free at those power levels. is the extra 4k worth all the upgrades for a 03-04 cobra, its up to the owner but in the long run it will cost more to upgrade the mach.
![]() bone stock from the factory! |
2003 Cobra
^ Good info there. Also, if you don't mind a higher mileage 03/04 Cobra, one can be found for your 18k price limit. Just be patient and search. You will never be satisfied if you settle. Good luck, the hunt is half the fun anyway!
Whippled 03 Sonic Blue Terminator
\/ Hidden Bewbs \/
01 Cobra Vert
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
I feel like if I switched from the 2011 chassis to a sn-95 chassis, as a DD, I would be thoroughly disappointed with the ride and comfort. If you really wanna get into a V8, why not grab a 05-09 GT? They wouldn't be much of a downgrade as far as interior build quality, but they're nearly as powerful as a Mach 1 or an 01 Cobra. Sure 4v's take mods better, but mods are more expensive. And our trannies SUCK.
![]() MM Cobra Club #66 |
2003 Cobra
I got my 03 Cobra for 15k. It was stock, low miles(44k) and was clean with nothing wrong with it. The guy just had to get rid of it. So I say keep looking for a 03-04 Cobra. There are great deals out there. Plus the Terminator is BEAST!!!
2004 Mustang Mach1
If you really want a Terminator then go for it. I bet you could find one with a bit of searching. As for miles don't let them scare ya. I know several Machs that are boosted or sprayin over 100k
2011 Mustang V6
All really good info!! Thanks Guys!!! I will prob hold off for the next few weeks/months. WIll def check out that Cobra in OKC. Cobra is prob gonna be the way I go for sure. Def would hate to settle.
2011 Mustang V6
Is this the deal you guys were talking about waiting for?
2003 Ford Mustang SVT Cobra, $15,900 - Cars.com Oh and btw its on 2033 miles from me.... :facepalm
2009 ROTY
oh my. that body kit is something else.... i think i'd keep on looking.... personally.
#20 | |
2011 Mustang V6
Threads Similar to: Which to pickup Cobra Or Mach?
| Will a 5.4 4v pan and oil pickup tube fit on my 4.6 4v? | Fraley225 | 4V / SVT | 4 | April 22nd, 2011 11:45 PM |
| Pickup Lines | r890 | The Clubhouse | 48 | April 25th, 2010 12:57 PM |
| Oil Pickup tube | BDaily | 99-04 | 4 | March 19th, 2010 07:11 PM |
| Vortech Mounts Different for 99 Cobra, 01 Cobra and 03 Mach 1…? | Owenslee | 4V / SVT | 1 | December 30th, 2009 11:49 AM |
