2ndPlaceSetofSteakKnives
What do I need for a T56 Swap???
I have a 96' Cobra and I picked up a 98-02 Trans Am / Camaro T56 for 650 bucks in good conditon and just wanted to know what all I need to install it correctly? I am going to have the driveshaft modified, is the bell housings the same? And I would imagine I need a different crossmember.
03' Cobra | 3.4 Whipple | SRA Swap | 99' SS | Forged 347 | YSI 16psi | 12 Bolt | 96' Cobra | On3 FF Kit | T45 Source Tranny | 3.55's | 91' GT | GT40 Intake | CAI | Headers | www.fquick.com/99Ls1fever |
Sorry I thought I was in the 4v Section, my bad!
MM's king of Neon's
404 - car not found
17.81@87
Well some of us 4v converts can help anyways. lol
Anyways, I'd say you're in some trouble if you bought the GM spec T-56. I'm receiving my T-56 this week so I'll give you the shakedown. The first show stopper is the shifter location. The GM ones use the main housing location, whereas the Ford ones use the tailshaft housing location. It's going to cost some to get them lined up. Or you can hack a hole in your console. Up to you. Now the other fun bits: Driveshaft- or modify your existing one. Harness- or modify your existing one. The big difference is the reverse solenoid lockout. Details in Jazzer's thread. Bell housing- I don't believe the Ford and GM ones are identical. Cross member- You can use the 03/04 Cobra, or hack and modify your existing one. I think those are the major ones. I believe GM at least uses the same mag pulse VSS as the Ford, but the Dodge does not. Also check what spline it is. T-56 typically come in stock 10 spline or upgraded 26 spline. EDIT: Jazzer's detailed how-to guide: T-3650 ~ T-56 swap in the works...
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
That link is awesome man, yeah it is the center section GM T-56, I am going to ask the guy that I go through for everything how much he will charge to move it to the rear. I am not going to hack up anything. I want to make sure I do it right. That thread link is bad ass, thanks again for posting that! I hope the rest of this goes smooth. I guess we will see
1998 Mustang GT
13.046@107.49
the 96-98 crossmember is different than the little 99-04 crossmember. You can use your stock crossmember it just needs to be moved slightly which your crossmember brackets should allow you to do. At least with a Cobra t56. I imagine that part would be the same.
Check out my project thread for a little more information on putting a cobra t56 in a 98 gt. Quite a bit should apply. Also with the gm t56 I believe the input shaft is too long so you will need a new one, and the bellhousings are different. The biggest hurdle is the shifter location as far as I know.
98 Mustang GT 13.795 @ 98.87 N/A Main mods: PI Swap, 3.73 gears, E85 ![]() My Mark VIII and T56 swap |
uh, this is starting to sound not so pleasent. I might ask my the guy who builds my cars if we can find a Ford one and just go from there.
#7 | |
MM's king of Neon's
404 - car not found
17.81@87
![]() You can see why I went with the straight up Cobra swap. Unfortunately it means you're going to have to shell out more. A GM T56 can be had for under $1000, but a Cobra will go for $1500+ all day long. Shit luck having a Ford, but what can you do? I had to bite the bullet because I need the extra strength, and the Cobra authenticity doesn't hurt either. Also I just confirmed my transmission is in at the terminal up in Indy, going after work! Woo!
Thanks for all the help ma, I appreciate the heads up and the insight. Keep me and us posted on your trans install!
Threads Similar to: What do I need for a T56 Swap???
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| pi swap or motor swap | whiteboy05 | 96-98 | 12 | December 8th, 2009 05:30 AM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
| 1995 351 to swap or not to swap.& how to? | Jeffery9508 | 94-95 | 9 | August 3rd, 2008 08:00 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
