MM's Orangest
2004 Mach 1 Mustang
How to clean up after a bad oil change...
So this afternoon I change the oil in the Ion and then move on to the Mach 1. For any of you that have changed the oil on a 4V you know it's a tight fit and a pain in the ass to get the filter back on (and off for that matter). So I'm tightening the filter back up and the hand tool won't move anymore so I thought it was tight. I had actually hit the aftermarket oil pressure sensor so you can now see where this is going. I fill the engine back up with Royal Purple...
I looked under the car and no leaks. I start the car up and back it off the ramps to move it over one spot in the apartment parking lot. I throw it in first and I thought son of a bitch the clutch is slipping. I turn the car off and get out. There is oil all over the parking lot. I ran back to the apartment and grabbed a 5 gallon container full of cat litter. I used all of that to clean up the oil that was scattered around the lot. Time to check that oil filter again. Oh it's not tight (point finger at head and pull trigger). Tightened it up and filled the oil. No more leaks. So for all of you out there have a good laugh and make sure to double check that the filter is tight before you turn your garage or parking lot into an ice-free skating rink.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
2004 Mustang Mach1
That sucks. With the tool I got you put it on the filter and can only only move it a couple cm. my problem lately has been putting the filters on too tight so it makes a nightmare to get it back off
#3 | |
2009 ROTY
dude! that sucks man. sorry to hear it. btw- a tubular k-member makes oil changes much easier.
03 Cobra
You dont have to do anyting more than hand tighten the oil filter if you lube up the seal, makes it alot easier to remove aswell.
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 |
Who needs titles...
1999 Mustang Cobra
Sorry to hear about your messy ordeal.
Must be something different with the area around the oil filter in the Machs and my 99 Cobra. Mine's easy to get to and take off, and put back on by hand. Gotta jack the car and drain the oil first, but other than that it's easy. |
2004 Mustang Mach1
Yeppers i do that every time
1996 Mustang Gt
9.9033@70.85 1/8 in rain(Stock)
Yup that's what I do, I just changed my oil and it took less than 15 min. When I first got my car it took forever since the filter was a bitch to get off
![]() Pacific Green 96 Gt |
2003 SVT Cobra
although access to the filter is much more open. with the oil cooler and tubular k member I can only use certain lower profile filters.
I buy car mods for the stickers, and I have ALOT of stickers! Travis Billings May 6, 1982 - July 5, 2011 Rest In Peace brother, you will be missed. |
I.D.G.A.F.
Tubular K member helped out a lot, and I don't use a tool to tighten my filters. I use my big ole bear paws. Never had one come loose in years.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
#11 | |
2009 ROTY
2000 GT 'vert
Out of 20 years of oil changes I forgot to put the oil plug back on before filling my truck about 6 months ago. I was in a hurry and poured all 5 quarts in too.
Sent from my Nexus One using AutoGuide App |
Threads Similar to: How to clean up after a bad oil change...
| Clean Up? | Befreder | General Car Care & Detailing | 6 | February 18th, 2011 12:59 PM |
| All clean | XTCNAGT | Pictures | 32 | May 12th, 2009 12:43 AM |
| Clean my IAC | trueblue02GT | 99-04 | 37 | April 29th, 2009 09:04 AM |
