M112 or M122 Swap
Old August 12th, 2011, 03:41 PM   #1
moneygreenstang's Avatar
2001 Mustang GT
moneygreenstang will become famous soon enough
M112 or M122 Swap
I want to supercharge my mustang with a PD supercharger. I figure itll be less expensive.
M112 03 Cobra Blower
M122 GT500 Blower
Heres how I would like to do it
Use the Lightning lower intake on my 2v 5.4 with either the stock intercooler or a custom set up.
I need to see pictures of the stock lightning lower intake with the intercooler mounted .
Here is how I got my inspiration/idea.. M112 on a Stock 5.0
Custom Lower intake.. I could just use the Lightning lower
Custom intercooler plate for eatons on 3800 v6's same idea would work on the 5.4 if i needed it to
Heres the tork tech kit on a 5.4
Heres a 5.4 with a lightning lower intake, custom block off plate, and a 99-04 mustang plenum with a centri
I planned on using the tork tech kit but at 1900 plus 300 for the 5.4 spacers, and 100 shipping. Basically 2500 out the door for the kit,
I could have a lightning lower, my choice of eaton blower, intercooler, intercooler pump, reservoir, and custom aluminum plate fabbed, heat exchanger alternator relocation, boost bypass valve, injectors, fuel pump, and maybe money left for a tune or blower cams at that point.
So my question is does anyone have pictures of the lightning lower with the intercooler so I can see if I need to custom fab an intercooler or will the stock lightning style work for me.
Dont tell me buy a cobra or gt500 or anything I already have the GT and Lightning and a F250
01 GT Vert - Triple Black - 2v 5.4 270/340
00 Lightning - Triple Black - 2v SC 5.4 400/500
Brand New Tubular UCA and LCA set for sale PM me
Slightly Used 05-09 Halo Headlights for sale PM me
Old August 12th, 2011, 04:18 PM   #2
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
pm shark bait, he may have a couple pics
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old August 12th, 2011, 09:30 PM   #3
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
The lightning lower looks similar to he 03-04 cobra lower but the coolant lines are on the back. Re lightning 112 has a diff bolt patern than the cobra 112 so they can't be miss matched without an adapter. The lightning 112 has a much taller stance cause the intake runs over the top. If I were you I would use a lightning lower with a whipple or kb. That way it would sit lower and make alot more power.
bone stock from the factory!
Old August 13th, 2011, 01:28 AM   #4
2001 Mustang GT
Thats my whole idea to make a bolt pattern adapter plate from the lightning lower to the cobra or GT500 blower.
Cost is the second reason. I already have a 2000 Lightning and dont want to spend 3000 on the whipple or KB kit. Id rather spend 3000 on the whole project.
above im referring to the cobra 112 and the gt500 122 because of the lower profile and side inlet. the 122 is even lower the the cobra 112. I am going to use the lightning intercooler and lower intake with the m122 and an apater plate, with a battery and alternator relocation.
Old August 13th, 2011, 01:40 PM   #5
I.D.G.A.F.
futureMACH1racer's Avatar
2009 John Deere 9670
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
It costs to go fast...
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old August 18th, 2011, 02:52 PM   #6
2001 Mustang GT
cost is right around 2000$ total - less if you're actually doing it on a lightning where you already have the lower intake, midplate intercooler, heat exchanger all that, ill be doing this on the mustang though the lightning is the DD.
About the same price give or take for a used centri kit, or a On3 kit, neither which will fit the 5.4 without modification.
Heres a guy whose made a kit to put the gt500 blower on the lightning
GT500 Blower on a Lightning - Lightning Forum | LightningRodder.com
Threads Similar to: M112 or M122 Swap
Split Port Swap/ Windstar Upper Intake/ M112 SC I SN95 I V6 Mustangs 20 April 1st, 2011 12:15 AM
Canidates for Eaton M112 Swap. Techniq All Other Vehicles 0 January 20th, 2010 10:32 AM
m112 on v6 SleeperStang88 4V / SVT 3 April 29th, 2009 01:30 PM
M112 on a 2V! Yes you Can!!!! ohcat68 99-04 14 May 2nd, 2008 09:16 AM
m112 mmvi V6 Mustangs 34 March 5th, 2007 03:38 PM
