03 Cobra issues
Old August 17th, 2011, 08:45 PM   #1
Sinister's Avatar
2003 Cobra
Sinister is on a distinguished road
03 Cobra issues
Hey guys, I got some issues with my cobra and hope you guys can maybe help. I made a video of all the problems I'm having.
03 Cobra issues - YouTube
Old August 17th, 2011, 09:46 PM   #2
moneygreenstang's Avatar
2001 Mustang GT
moneygreenstang will become famous soon enough
take off the wheel and look to see if the springs are different on each side, also look to see if the side that sits lower A Arm is bent.
If none of those jack the car up and measure the k-member and see if it looks bent.
As for the rack and pinion you might need new tire rods, ball joints, or just a whole new rack. A shop should be able to figure that one out cant tell from the video.
For the EGR just delete it
As for the Eaton/Ford SVT thing they are just different. My lightning has something different than what ive seen on other cars. Dont worry.
01 GT Vert - Triple Black - 2v 5.4 270/340
00 Lightning - Triple Black - 2v SC 5.4 400/500
Brand New Tubular UCA and LCA set for sale PM me
Slightly Used 05-09 Halo Headlights for sale PM me
Old August 17th, 2011, 10:05 PM   #3
4valvegt's Avatar
03 Cobra
4valvegt is on a distinguished road
Usually when the hi side of your dpfe (sensor for the egr) blows off its because of a restriction in the exhaust, more than likely plugged catalytic converters, most shops are able to test for excessive backpressure.
MM Cobra Club #86
2003 Mineral Grey Cobra
2004 True Blue F-150 FX4
Old August 19th, 2011, 01:00 AM   #4
Frdlvr35 is on a distinguished road
You need to take it to a good front end shop. A shop that specializes in front end work. The ride height difference from left to right can be caused by a number of things. Most obvious is springs, but a car that has taken a hard hit could have a number of other issues. Suspension or unibody iteself. The creaking in the steering is likely outer tierod ends. Seen it many times on the sealed factory tierods. But a front end shop can check this very easily. If the DPFE line is blowing off the you have an exhaust restriction. Easiest way to check is to put a vacuum gauge on manifold vacuum and make sure it is 17-19 inches of vacuum at idle. Low vacuum indicates restricted exhaust. No other way to check it other than drop the exhaust manually. Its not rocket science...
Old August 19th, 2011, 07:16 PM   #5
4valvegt's Avatar
03 Cobra
You can remove the upstream o2 sensors and install a backpressure guage, def the most accurate way of doing it and very simple.
MM Cobra Club #86
Old August 22nd, 2011, 10:33 PM   #6
94cobra pace,95gt98cobra
rag-top_man is on a distinguished road
they test cats by drilling a 1/8 hole in the exhaust pipe before and after the cat and measuring the pressure difference. I don't know your specific numbers but a decent exhaust shop should.
Old August 23rd, 2011, 08:37 AM   #7
4valvegt's Avatar
03 Cobra
Looks like there are many ways to test
MM Cobra Club #86
Threads Similar to: 03 Cobra issues
96 Cobra manifold vacuum issues 8 BALL 4V / SVT 0 March 13th, 2011 02:14 PM
93 Cobra Idle issues 93cobra 5.0 Mustangs 22 October 23rd, 2010 02:27 AM
96 cobra cooling issues mystk96 4V / SVT 13 June 26th, 2010 06:16 PM
Potential issues to look out for? 1999 SVT Cobra idesigner 4V / SVT 21 February 14th, 2010 04:16 PM
99' Cobra ABS issues 99CobraAR 4V / SVT 5 February 11th, 2010 02:15 PM
