Cobra overheating after install Meziere pump & radiator
Old August 22nd, 2011, 04:23 PM   #1
agent-orange is on a distinguished road
So I installed last week a new mishimoto radiator and a meziere waterpump. Now I have the problem, that my engine runs extreme hot, but the thermometer shows normal temps, it's right in the middle. But the engine is so hot, that I burned myself. But the pump runs, I hear it.
I thought that there is still too much air in the system and a drain the coolant again today. I worked with the "burping the cooling system" how-to on this page. Could it be that I have so luck, that the thermostat got broken??
Because when I start the engine and wait some minutes, I feel that the crossover start to become hot really fast. From there the heat goes down to the thermostat housing and the upper radiator hole. The radiator also become hot around the upper hose hole.
so what could that be?? Thermostat or water pump? Or maybe both??
Thanks for help
Old August 23rd, 2011, 02:49 AM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
if it was water pump you would spill coolant out the cap. i ran the same water pump for years and car ran cooler. i would say double check your wires, do you have them crossed? as in the pump is spinning the wrong direction maybe (reaching on that one). also pull the thurmo out and replace it, its cheap so i would just replace it. also on the driver side there is a threaded in plug. i always unscrew it and fill the coolant into that.
bone stock from the factory!
Old August 23rd, 2011, 04:22 AM   #3
I use the wiring kit for it. The ground is directly on the ground of the battery, the +12V cable (orange) is connected with the alternator and the Switch source is connected with this cable plug thing at the passenger side (dont know the name) with Pin-9. I thought that, that the pump could maybe spinning the wrong direction.
How do I know, that the pump spinning the wrong way?? Should the warm water flow from the crossover to the upper hose into the radiator???
Old August 24th, 2011, 10:44 AM   #4
Look Ma! My First Post!
1leg is on a distinguished road
You should try calling Mezieres if you need help.
Old August 25th, 2011, 03:38 AM   #5
it works now, a guy told me that 188 fahrenheit isn't really hot after 30min at idle.
Threads Similar to: Cobra overheating after install Meziere pump & radiator
Which Meziere Pump??? cbjohnson9 99-04 4 June 23rd, 2011 05:47 PM
Overheating with dual core radiator BlownSmoke 5.0 Mustangs 4 September 4th, 2008 09:08 PM
Meziere electric water pump install? jivepepper 99-04 5 August 7th, 2008 05:09 PM
Meziere Water Pump 06VistaBlueGT 2005 - 2010 1 July 20th, 2008 12:16 AM
2006 s197 3v, meziere water pump install. need some help with wiring. navyman8903 2005 - 2010 0 June 22nd, 2008 11:39 PM
