2003 Mach 1
13.1@108
How can i get 400+hp in my 2003 Mach 1 being NA
As if right now i have a JLT Intake, MRT O/R H-Pipe, Borla Cat-Back, 4.10 Gears and a SCT Flash Tuner. I dont want Nitrous or Boost. I will be Porting my Intake upper and lower along with a PHP Intake Spacer and getting an Electric Water pump, bigger MAF, Injectors, and Plugs. What else do you think i would need. I would really love to have about 420hp to the crank, just so i can say i have as much horsepower as a stock 03-04 cobra has
Go to svtperformance.com and register there are plenty of N/A machs over there running high 3 hundred hp. At the wheels One guy i know has a 98 cobra with c head swap and set of cams and other supporting goodies thats running like 390 at the wheels. With gobs of torque. Id ask them.
1989 LX Coupe
7.1@99mph
^ IDK if id believe 'gobs' of TQ. NA 281s with supporting mods don't usually have much TQ, def not enough to say 'gobs'. Most in the 330-350rwtq range...390rwhp is doable NA...but it takes more than just stock stuff.
Ive done multiple 4v combos, all from 353-365rwhp. All stock Longblocks with proper cams and install. Just takes the right list of parts and the right builder knowing what he is doing.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
Well I just mean over the b set of heads like I have sorry
2003 gt
5.4 32v on the way
Just a heads up, you wont likely hit 400+ NA for less than it would take to do it FI. Look into the 5.0 Big bore boss block and a stroker kit for it. You would end up with a 5.3L motor and with higher compression and the right cams you will make it to the 400hp mark.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
1989 LX Coupe
7.1@99mph
Roger that. True. You will get better TQ through C heads than B...but still not 'gobs'. lol.
#7 | |
1989 LX Coupe
7.1@99mph
So...your big bore stroker method of spending 10K on a motor for 400hp...um...is retarded. Sorry. Ive done it back to back on numerous motors...for cams and bolt ons...stock intake...do the math. If I had a nickel for every time Ive argued this point on 32v 400hp...id have a shit-ton of nickels...
2003 gt
5.4 32v on the way
Well congrats on the 360hp 4.6, that is a decent number for a stock motor. However if you check out corrals NA list you will see plenty of examples of a 4.6 in the mid 300 range, but not so many after 370. I don't meant to take anything away from you, but to ask for 400+ out of a 4.6 without anything crazy is really pushing it.
Edit My bad I just noticed that the op wanted 420 crank not wheel. Ok you win.
2003 Mach 1
13.1@108
Yeah, i probably should have been more clear on that, but yeah I am looking for crank horsepower. So are you saying all I'd need to add a set of cams to my list of to-do mods and I'll be good. I'll be getting most of this done over the winter at a shop that specializes in mustangs. I want to be ready for when the spring hits.
MM's Orangest
2004 Mach 1 Mustang
Yes a good set of cams that are installed correctly will get you where you want to go along with the other mods.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
Authorized Vendor
![]() Join Date: Feb 2009
Cams will indeed get you to 420 crank HP, assuming you have all supporting mods.
My car made 346 RWHP with a stock 03 Mach 1 engine....and 96-98 Cobra INTAKE cams only....with bolt-ons (supporting mods) With a short runner, I think it wouldve made somewhere around 355-360....to the tires, which would have been somewhere around 410-420 flywheel HP. With stock cams.
Kelly Aiken "The Ford Guy" BMR Suspension Inc kelly@bmrsuspension.com 813.986.9302 CLICK IF YOU LIKE BMR SUSPENSION |
2003 Mach 1
13.1@108
I heard the 96-98 cobra cams are good but what are the redline on them? Also are there a better set of cams like some comp cams I can get is the price per horsepower not worth it?
2003 Mach 1
Procharger???
i can say its definatly worth it. Im running 454 rwhp on my 03 Mach and definatly worth every penny. Might as well go all out, u wont ever regret it.
2003 Mach 1
13.1@108
again like i said, i dont want boost, im only 20, almost 21. Im not looking to dump all my money into my mach 1 and if something where to happen to my engine i would be f**ked, and plus i want to start saving up for other things. I would love to have a procharger, i really would but im not ready to spend $6k+ tuning on my car. I would be completely satisfied with around $3k to get me 400+ hp while still staying in a comfortable save zone because i am on 96k miles
#15 | |
2003 Mach 1
Ya makes sense. Im 20 as well, just bought the mach 2 weeks ago. 24K miles, and the upgrades (procharger, exhaust, upgraded fuel system) were already on the car. But good luck man. Once you get at 400+ the thrill only gets better. |
#16 | |
1989 LX Coupe
7.1@99mph
Even if he wanted 420rwhp, he doesn't need big bore and stroker. My motor did 426rwhp NA at 6900rpm and power was still climbing. I'll get you a dyno graph with the current setup. I expect no less than 450+rwhp on pump gas.
2003 gt
5.4 32v on the way
hitting 426 on a 4.6? Well that just gets my hopes up with my 5.4. Openly my goal is 430+, looking forward to mid 400s, and am secretly crossing my fingers for 500.
#18 | |
03 TR Mach
8.39 @ 87
4v Know-it-all
96-98 cams only add 20rwhp. 420 at the flywheel is very easy to achieve and it doesn't take a lot of mods to get there, just cams and long tubes.
2003 Mach 1
13.1@108
im guessing i should i just stalk ebay and forums to see if anyone is selling them?
Threads Similar to: How can i get 400+hp in my 2003 Mach 1 being NA
| 2003 Mach 1 | ICFlash | 4V / SVT | 16 | January 17th, 2011 12:00 PM |
| My Car vs a 2003 Mach 1 | 04GTNAustin | 99-04 | 44 | July 20th, 2010 11:28 PM |
| first 4v! 2003 mach 1!! | 94pacecarSVT | 4V / SVT | 6 | November 11th, 2009 11:22 AM |
