Strange Noise. What could it be?
I have a 98 cobra.
It makes a strange noise that i would describe as a clunking sound. This happens when i accelerate and when i let off the gas - only in gear. If i hold a constant RPM/speed the noise is nonexistent. This noise occurs about 75 % of the time that i accelerate/decelerate. It is very annoying/embarrassing when audible. Anyone know what to start looking at or what it could be?
BBK CAI. H pipe/dual flows. 4.10s and tlok. window tint. Bullits. SCT Tuner. |
2001 Mustang GT
9.30 @ 77mph-1/8th mile 2.2 60'
![]() iTrader: 3 reviews
5 speed or auto? coming from front or back? which side? start by checking your lug nuts..mine was doing the same a month or so ago and i thought it was a u joint. turned out that the drivers side lugs on the rear were loose and had bout half an inch of play in the wheel lol. other than that it sounds like u joints to me. thats what i would put the bet on
01 GT. 5spd , 03-04 cobra clutch, on its 2nd 4.6l motor 2nd tr3650 too,JLT CAI,UPR o/r x, magnapack catback, predator tuned, H&R ss 10.5" bullitts w/ nt555r DR's
5 Speed. Ill check that out man, thanks. Its actually kind of hard to tell which side, ill pay more attention to it the next time im out.
So the noise seems to be coming from the front of the passenger side of the car.. Again it is a clunking/ squeking sound.
Anyone else had a similar experience or know what could cause this?
2001 Cobra
14.2@102 (I suck)
I think I am having the EXACT same problem haha. Can you almost feel it in the pedals?
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
tranny mount loose?
1995 Mustang Gt
loose exhaust?? hanger broke off exhaust is what it sounds like
95' GT, Trickflow setup, Aluminum heads with 1:6 roller rockers, e303 cam, BBK shorties into Magnaflow exhaust, BBK cold air intake with 75maf, Highperformance waterpump w/ electric fans |
Priest of the Car Gods
he said it was a cobra.OP, did you do your brakes any time recently? I had a similar issue when I bought a set of pads and they had forgot to put the anti-rattle clip in the box (and I didn't know enough at the time to know it was necessary). Once I got it in there, the clunking went away.
Bringing Yellow Back
motor mount? u joint? trans mount?
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
#10 | |
Ill check out the exhaust hangers.. And Reverend, no brake work has been recently.
#11 | |
P.S. How do i quote everybody?
#12 | |
You still may have lost one of those clips. If it is the brakes, at low speed you'll get a clunk every time you tap or release the brake pedal (as the caliper bangs around in the bracket). See the button next to "Quote" that just has a "-" in it? That's multi-quote. Just hit that on all the posts you want to quote but the last one, and hit the normal quote on that.
ball joints maybe?
I would bet on a motor mount based on the noise you are describing. With the Park brake set tight, let out on the clutch(In Gear) while somone else observes your engine to see if there is excessive engine movement under load. They meight even hear the clunk....just a thought.....Make sure there is nothing in front of the vehicle...to include your second set of eyes....just in case....Good luck
Threads Similar to: Strange Noise. What could it be?
| strange noise | 4.6DreameR | 99-04 | 4 | June 2nd, 2011 02:39 PM |
| Strange noise | ia07gt | 2005 - 2010 | 27 | March 11th, 2010 12:04 AM |
| strange noise | disturbdgt | 99-04 | 18 | February 17th, 2009 11:40 PM |
| Need some help with strange noise...... | bullitt01 | 99-04 | 28 | December 2nd, 2008 02:10 PM |
| Strange noise | willsurforbeer9 | V6 Mustangs | 9 | January 3rd, 2008 10:13 AM |
