#21 | |
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
2000 Mustang GT Built 4V Motor with Sullivan Single Plane Intake Custom 66MM BB TT kit Borla XR-1 Dumped before rear Moser built 9" Rear 35 spline WaveTrac Diff with 3.75s 35 spline Moser axles 14PT roll cage and minitubbed
#22 |
1989 LX Coupe
7.1@99mph
'Handle' and 'Rated' are two different things.
I know they can. Ive pushed them past what they are rated...and Ive seen stock longblocks do 850+rwhp. If you guys would read, I said rated. Never said they COULDN"T handle more power, just said they are rated at 700hp.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
#23 |
2003 gt
5.4 32v on the way
I dont know about you guys, but if I was putting together a motor for 800hp+ id throw in the extra cash for a nice set of I beams that are rated past what im shooting for instead of using H beams rated less than what ill make. I know people make a bit more power than the 700hp that manley rates the H beam rods at, but id like to be safer than save a buck.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
#24 |
2002 GT
That's a ton of great info! It won't be until the middle of next year before I can actually make something happen I have kicked around the idea of keeping my GT and just building it up a little. If I do that I am still looking at a good 9-10k with a kenne bell and maybe a little bottom end work. I like the idea of a fairly stock looking GT that will stay close to a cobra,vette or whatever. What do y'all think?
mac cold air intake,5.0 short throw shifter, frpp 3.73,frpp b lowering springs, upr upper and lower control arms, mach1 grille delete
#25 |
2002 GT
Just throwin things out there how about 03-04 cobra motor in my GT? I know this has done before just curious I guess. Still lookin at 10k at least
#26 |
4v Know-it-all
$10k is a lot of cash and too much IMO. You can get a complete 03/04 engine with blower for $6-$7k.
#27 |
MM's king of Neon's
404 - car not found
17.81@87
I paid $3500 delivered for my long block. Another $2500 for my suped-up Eaton swap with it, and probably another $100 or more in gaskets and fasteners, though some weren't necessary, just peace of mind.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#28 |
2002 GT
Yeah you r right 10k is a lot. I will have it installed by someone else and tuned and all that so that will be a big chunk of it there. I think that is a good # start to finish don't ya think.
#29 | |
MM's king of Neon's
404 - car not found
17.81@87
And of course with an installation it's going to cost you big money, labor isn't cheap. I'll work for a couple bucks, beers and pizzas. It also depends on how complete the engine is. I've spent most of my time piecing everything together and installing cams. If it's a completel liftout that will cut down on labor.
#30 |
2002 GT
I have done my fair share of engine builds and what not in high school and what not but that was more than a few days ago LOL! is it really worth it is the big question I guess?
#31 | |
A lot of people are under the impression HP breaks parts, thats really not the case. RPMs are what break parts. Thats why they say the Manleys are rated to 700hp at 8000rpm.
#32 |
1989 LX Coupe
7.1@99mph
^ either OR usually wont break parts. WHen you start mixing the two is when you start breaking stuff.
And 10k is retarded. I have less than half of what it would cost someone building my big bore motor on a site like MP or Livernois. I literally have 2200-2300 in my shortblock, thats including machine work. Look on other sites and see what companies charge for a big bore shortblock. Ppl really need to start doing research and sourcing out parts and building stuff yourself. It isn't rocket science. And when you do it yourself. YOu get piece of mind its done right...
#33 | |
MM's king of Neon's
404 - car not found
17.81@87
#34 |
1989 LX Coupe
7.1@99mph
^ My bad. 2400-2500. Forgot about the expensive main studs.
I find stuff and make it work. I spend where only needed to be spent.
#35 |
2003 Mustang Mach 1
And just to clarify, there's no such thing as a "bullet proof engine"!
Here's an example of what happens when a billet I-beam rod meets up with 2 inches of liquid gasoline inside the cylinder when the motor is just being started!
#36 |
MM's king of Neon's
404 - car not found
17.81@87
False. My motor is impervious to small arms fire up to .308 caliber.
#37 |
1989 LX Coupe
7.1@99mph
lol. Perfect. What about a 50 cal?
#38 |
04 Cobra
Had a Mach for 3 years, now I own an 04 Cobra. Honestly if I were to go back I would have just gotten the Cobra in the beginning. Both are badass 4V cars though.
Threads Similar to: 4v engine
| 2005 V6 engine swap to 2002 saleen engine | MCLARK | V6 Mustangs | 7 | May 14th, 2010 06:02 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| Engine install: Life engine up, or drop engine? | trill gear head | 2005 - 2010 | 14 | October 26th, 2009 01:17 AM |
| Washed n cleaned engine today.. pics of engine bay. | MustanG_guy17 | The Clubhouse | 40 | January 4th, 2008 10:14 PM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 05:09 PM |
