2003 Mustang GT
04 Mach 1 in 03 gt swap. End all be all help thread.
Hey guys! Long time lurker, first time member/poster. Ok here's the deal...I have an '03 gt 5-speed and the motor took a dump on me. After calling around and touching base with some local mustang buddies I came across a 04 Mach 1 auto that's been wrecked and I can snatch whatever I need. After doing countless hours of reading I'm still confused so... WHAT ALL DO I NEED!!! I've read use the ecu and engine harness but keep my firewall and dash, or hack my stuff up and go, throttle and cruise cables, everyone has their opinion so guys, help me here. End all be all parts list so I can do this.
2003 Mustang GT
To clearify, I know all about the coolant parts stuff, crossover, T-Stat, hoses etc. Mainly just confused as $h!t about wiring. Like can I just simply plug the Mach engine harness to the firewall harness and swap ECU's and roll. I've already got the PATS part taken care of if that's the case.
MM's king of Neon's
404 - car not found
17.81@87
If you can pull the ECM, do it. Then you won't need any wiring or a re-tune. Since you've got a donor it should be a piece of cake.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2003 Mustang GT
When you say no need for wiring are you implying none at all or the engine harness and ecu combo like in my second post. Sorry If I'm asking to be spoon fed, the donor car is about 3 hours away and the nearest tune shop is about 2 hours away. Perks of living in BFE... I just have pretty much a one shot at getting EVERYTHING and want all my ducks in a row.
#5 | |
MM's king of Neon's
404 - car not found
17.81@87
And when in doubt, pull it out. Better to have more parts than you need than not enough.
2003 Mustang GT
That's pretty much the plan. I was just curious when install comes what parts could be universal plug and play. Like the engine to ECM harness connection, is it truly plug and play or am I gonna have to install the ECM side harness too. Since I finally bit the bullet and joined up I figured I might do a write up when time comes. I'm just praying for a clean, painless install. Then I can come and play with my big brothers in their 4v's.
2003 GT
Told you.
2003 Mustang GT - Whole buncha crazy stuff done to it. One foot on the gas. One foot in the grave. |
#8 | |
MM's king of Neon's
404 - car not found
17.81@87
Expect lots of headaches though. I know I am, and I've already run into my fair share just piecing things together. Good luck with the writeup. We'll have to see who gets their project together first, you or me. ![]() EDIT: Waaaaaaaaaait. Slight issues. Are you pulling the engine with the transmission? If not you will need to swap over your flywheel/clutch, and you might be better off keeping your ECM. Auto ECM's "look" for a TCM (with the auto trans), and if that isn't there, it throws a code.
2003 Mustang GT
Nah, I'm staying with my manual tranny. I'm not going to a slush box. And if a code is all i'm worried about there then so be it. I can ride with a CEL on 'til I can take it to the speed shop.
June 2010 ROTM
2000
HPDE Instructor PCA, HOD, Track Guys, ERME www.RaceCarTowHooks.com My Track Videos http://www.youtube.com/user/Msirlin My Garage page: http://www.moddedmustangs.com/forums...-member-17090/
1989 Coupe
11.49@124
My '01 GT has a '04 Mach 4-valve w/Eaton swap. It is running off the factory GT computer but, the 4R70W was also retained.
#12 | |
MM's king of Neon's
404 - car not found
17.81@87
I think the code is a P700 regarding the TCM. I know with autos if the TCM isn't recognized it will throw it into limp mode and won't let you shift out of a certain gear, but I don't think that will be an issue with a manual.
2003 Mustang GT
Awesome Possum. You guys have been a big help, thanks for the info. Oh and Wicked, I'm starting the swap next weekend.
2003 GT
Stop googling, and get ready to bleed some more over this Mustang.
2003 Mustang GT
Ok little update. After calling around I have definitively found out that the Mach engine harness will not work with the GT firewall harness. So, looks like I'll be modifying my 2v harness and using my GT ECM. Now, if someone has done this already (and I know a lot of people on this site has) Please, pretty please with a blower on top... Contact me. I need some one to clear up what wires need to be lengthened, swapped, etc. I have the Mach engine harness so I'll be able to steal the connectors/wires off it, just need someone with personal experience with this to kinda walk me through it.
Threads Similar to: 04 Mach 1 in 03 gt swap. End all be all help thread.
| 99/01 Cobra and 03/04 Mach 1 FACTS, and Basic Mods thread | KingChronic | 4V / SVT | 84 | May 12th, 2012 10:03 AM |
| 351 swap into a 98 gt thread | thoroughbred | 96-98 | 2 | March 3rd, 2011 11:22 PM |
| My Swap Thread | Megawatts88 | V6 Mustangs | 104 | December 28th, 2010 06:42 PM |
| Definitive 5-lug swap thread? | ReverendDexter | 5.0 Mustangs | 20 | May 27th, 2010 09:28 AM |
| Epic Motor Swap Thread? | DiZzyBonne | The Clubhouse | 6 | September 15th, 2008 11:31 PM |
