Timing Cover Stud?
Old September 26th, 2011, 08:55 PM   #1
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Timing Cover Stud?
Does anyone know the importance of the furthest outboard timing cover stud on the passenger side of the 03/04 Cobra? The stud itself is a discontinued part, and I'm wondering if it's necessary to hunt down this damned $24 part. If it's just for a p-clip for the A/C or harness, I really don't care.
And on a sidenote, does anyone know the crank bolt washer size?
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old September 27th, 2011, 05:23 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the studs are just there for interchange or brackets. there are couple on there that arent being used.
Old September 27th, 2011, 05:24 AM   #3
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
as for the crank bolt washer, not sure the size but i believe i have a few of them running around if i havent tossed them.
Old September 27th, 2011, 09:00 AM   #4
MM's king of Neon's
404 - car not found
17.81@87
Thanks for the info. From the pictures I had seen it was mainly as a P-clip for the A/C lines, though you think that would make it common with the 2V and other 4V motors. I'll just order another one of the regular studs.
As for the crank bolt washer I'm going to try and just find a grade 8 washer for it. If you've got one lying around PM me and I'll send you a few bucks for it though.
Old September 27th, 2011, 11:14 PM   #5
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
there is a small stud just for the ac line, that will interchange with the 2v as well.
Threads Similar to: Timing Cover Stud?
Valve cover stud kit shadow88 5.0 Mustangs 0 September 13th, 2011 06:06 PM
1979-93 Mustang Timing Cover & Water Pump Stud & Bolt Kit Exclusively @ LRS! LRSjmac LatemodelRestoration.com 0 September 6th, 2011 01:53 PM
Timing cover stud Garhfer 99-04 2 October 31st, 2010 07:38 AM
Help Please Timing Cover!!!! Stang281GT 99-04 12 July 9th, 2008 05:53 PM
timing cover Black Five 0h 5.0 Mustangs 3 April 17th, 2008 09:52 AM
