MSTRB8N & MDR8N
2021 Mustang V15
Quad Turbo with nawz
Any tips or advice for installing long tubes on a 97 cobra?
just bought flowtech long tube headers, BBK o/r x pipe, o2 extensions, and sct sf3/x3 tuner for my 1997 cobra.
i've never installed headers on anything before, so this is totally new to me. if anybody can give me any tips or advice that will make this go as smoothly as possible, i would greatly appreciate it
Shelby's Minion
Have a hoist!
![]() Sponsored by Specialty Coatings Car Salesman Club- Founder -------------------------- 2007 Shelby GT- Hardparked
2003 Mach 1- Hardparked 1988 LX 5.0- Umm...Driver? |
1989 LX Coupe
7.1@99mph
Remove the K member/Suspension. Install headers.
Install K member. Good luck with the flowtech. Tried 3 diff sets...none fit right.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
2009 ROTY
if you don't already have a tubular kmember, i'd do it at the same time since its gonna be off.
1989 LX Coupe
7.1@99mph
I was gonna say that...
1989 LX Coupe
7.1@99mph
BBK. Kooks and ARH. You get what you pay for...
01 Bullitt 429rwhp 391tq
Have fun changing ur clutch...LOL
Blk #200 Mods: V2-SQ Vortech w/Aftercooler 10psi, built motor, custom blower cams, Full MM suspension 429rwhp 391rwtq need a new alt..
1998 Mustang Cobra
for sure drop and replace the k member, and use stage 8 locking header bolts so you dont have to do it again. I would also recommend an MLS style gasket. Ford Racing sells a set for about $60. just my $.02 though
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner |
Bringing Yellow Back
its easier on jack stands if you dropping the k
jsut use a jack to hond the engine up while you install the headers but yes make you life easier and drop the k TRUST ME also double check the make sure the matting surface ont he headers is straight before you put them on, i had a problem where it was not straight and had to remove the head and fix it ( which sucked ass) also use the stock studs in any place you can ( some you will have to use the bolts) this way they are easier to install and its less bolts to come loose
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
1989 Coupe
11.49@124
Sell em' and buy Bassani mid-lengths. Same hassle to install but at least you don't have to unbolt them to drop the tranny.
wiht flow techs you dont need to loosen them to remove the tranny
1989 LX Coupe
7.1@99mph
As someone mentioned...use the stock studs. Use them everytime and I have NEVER had one back off...Run a tap through the nuts to help them screw on easy...and wrench the piss out of them.
Resident DJ
'01 Cobra Vert.
Lots of beer Bubba
Like others said beer and patience.
![]() Sig by Tricep |
1989 LX Coupe
7.1@99mph
It isn't that bad if you have a tubular K member. I can do BBKs in a 96-04 in 1 hour or so...Thats just install. Add another hour for removal of old headers.
Threads Similar to: Any tips or advice for installing long tubes on a 97 cobra?
| P0401 (egr valve?) code after installing Long tubes.. | tbmd | 2005 - 2010 | 0 | June 24th, 2011 01:52 PM |
| Long Tubes, quick questions for those who have done it. (98 cobra) | PowerShiftz02GT | 4V / SVT | 13 | May 6th, 2010 11:21 PM |
| Installing long tubes | rider4life350 | 99-04 | 12 | December 28th, 2009 12:20 AM |
| Long tubes on an 01 Cobra...worth it? | Diabeetus | Modular Mustangs | 5 | August 23rd, 2008 12:43 AM |
