2001 cobra
Hey guys need some help on an eaton swap
Hey guys well im about to get some extra money coming in and wanted to do add an eaton supercharger on my car because its the perfect amount of hp i would want my car to have, and love how they sound. So i was wondering what parts would i have to buy do put that eaton on my 01 cobra, is it alot fo parts?? is it worth it? I would like to know what parts i would need to buy
![]() SVT all day! Next mods: Mickey thompson street radials, new wheels, gears and tuner, then turboed by 2013
1989 Coupe
11.49@124
The parts list is extensive but the swap is worth it IMO. My GT has a 4 valve w/Eaton swap. It makes 411 through the stock auto. Only mods are 4:10's, CAI, and tune. With an IRS in the car, it has gone a best of 12.41 @ 114. It has 12.20's in it the way it sits and high 11's with a converter. This is also with stock pullies, so a pulley swap would probably put it in the 11's also.
Here is a parts list........ 2r3z6312baa - Crank pulley /Harmonic Balancer f1az6378a - washer for balancer f5rz6a340b - bolt for balancer 2r3z6312ba - Supercharger Crank drive pulley 2r3z10153ca - Bracket that replaces stk. alt. on 99-01 Cobra’s and 03/04 Mach 1’s (Comes w/ pulley below if bought used) yw7z8678aa - pulley for above bracket 2r3z6b209bc - Pulley bridge assembly for S.C. (If bought new it comes with the bridge, 2 idlers and tensioner) (8678B) Idler pulley,timing cover pass. side yw7z8678aa - pulley on drivers side of timing cover (6D080) Timing cover (if bought new, it comes w/ pulley on drivers side and tensioner) s5az6700a - timing cover seal (10A313) Upper alternator bracket (10153) Lower alternator bracket (10346) Alternator 1U2Z-14S411-TA Electrical connector (alt. to harmness ) (6B209A) Tensioner on timing cover 2r3z8260ab - Radiator hose 2r3z8a593ab - Radiator hose 2r3z8k576aa - Radiator hose 2r3z8548aa - Water cross over pipe (6881) Cobra oil cooler adapter (6A642) Cobra Oil cooler 2r3z9002aa - Cobra fuel tank (optional) 2r3z9h307ab - Cobra fuel pump (optional) 2r3z6f066aa - Eaton supercharger 2r3z9424bb - Lower intake (6K775) Garrett factory intercooler 3U2Z-14S411-SSA IAT2 sensor connector 2r3z9n491ca - Intercooler hard lines that hug the block (If bought new, it comes w/ part # 9l443c) (9N491A) Intercooler hard lines that come from the h/e 3r3z9l443aa - Intercooler line that goes from the i/c adapter to i/c res. 2r3z9l443ba - Intercooler line that goes from the i/c adapter to the hard lines that hug the block 2r3z9l443ca - Intercooler line that goes from the hard line against the block to i/c pump(included w/ the hard line that hugs the block if purchased new) 2r3z9l443da - Intercooler line that goes from hard line to hard line 2r3z9l443ea - Intercooler line that goes from hard line from h/e to i/c pump 2r3z9l443fa - Intercooler line that goes from hard line and connects to h/e 2r3z9l443ga - Intercooler line that goes from hard line and connects to h/e f8yz8501aa - Ford / Bosche water pump for intercooler 2r3z8n500ac - Intercooler pump bracket 2r3z8k226aa - Factory heat exchanger 2r3z8a193aa - Heat exchanger mounting bracket 2r3z8c386aa - 2each bracket clamps for h/e (9N491B) Lower manifold to intercooler water adapter 2r3z9a589ca - Plenum (9B659) Intake tube from maf to t/b. (9F715) IAC valve 2r3z9f593ba - Injectors (6F089) Boost bypass actuator 2r3z9a825aa - Cruise control cable 2r3z9a758aa - Throttle cable (9728) Throttle and cruise control cable mounting bracket 1l3z12b579aa - MAF xw4z9d475ab - EGR valve 2r3z9d477ad - EGR tube (6C324) PCV tubing (9F479) Sensor on the back of the S/C (9J432) Bracket for vacuum stuff on left side of the S/C (9H465) Vacuum stuff (9J459) Vacuum stuff (9J460) Vacuum stuff (9E498) Hose's or tube cluster of connectors for the vacuum parts above e83z9f670a IAC gasket 2r3z6020aa - Timing cover gasket LH side 2r3z6020ba -Timing cover gasket middle 2r3z6020ca - Timing cover gasket RH side 2r3z9h486aa - Lower intake to S.C. gasket 2r3z9l437bb - Plenum to S/C gasket e6az9d476b - EGR gasket 2r3z3490aa - Power steering resevoir bracket. I/C resivoir tank i/c pigtail S/C 8 rib belt inner acc. belt. n804178s309 - (8) Nuts for plenum, coolant crossover and pulley bridge can be picked up at local auto parts store in help section. n805164437 - (1) Bolt for pulley cage to timing cover. n808102s437 - bolt that is used on the idlers and pulleys. Only need if you buy parts seperately. You will need a total of at least 6 of these. n808920s437 - Pulley bridge bolts n606677-s36 (4) Bolts to bolt the bracket clamps to the h/e bracket N605909s437 - (4) bolts for the upper alt. bracket n807274s437 (1) lower alt. bracket to alt bolt n811313s431 (4) studs to bolt plenum to s/c w506404s437 (10) i/c to s/c bolts
Resident DJ
'01 Cobra Vert.
See my sticky in this section. It's under "useful links, etc."
2001 cobra
is there any place that sales are that together by any chance??? lol thats so many parts how expensive is it?? damn i thought it was wayyy easier then this :/
Resident DJ
'01 Cobra Vert.
A guy over on SVTP sometimes sells used "kits". Forget his name though...post up over there in their classifieds.
03 Cobra
![]() iTrader: 1 reviews
I had about 2 grand into my swap without the cost of tuning but I pieced it all together. Was worth every penny
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 |
Threads Similar to: Hey guys need some help on an eaton swap
| 99 Cobra Eaton swap! | 4valvegt | 4V / SVT | 81 | April 7th, 2011 10:22 PM |
| eaton swap | 01snak3 | 99-04 | 20 | February 4th, 2011 08:27 AM |
| Eaton swap kit | DevanMustang01SVT | 99-04 | 26 | January 11th, 2011 07:12 PM |
| Eaton swap on a mach 1 | 2003MACHWON | 4V / SVT | 11 | November 7th, 2010 07:25 PM |
| eaton swap.. | flatlinerford | 99-04 | 14 | November 9th, 2009 06:19 PM |
