MM's king of Neon's
404 - car not found
17.81@87
Dual FPDM Time!
I'm getting ready to set things up for a dual FPDM.
I already snagged from a junkyard a 2nd FPDM, with the connector and about 9" of wire on it. Here's where my questions are. I'm looking to set up a plug and play harness, and minimize the hacking done. Where can I get the plug that would be the same as what's on the FPDM's face, basically one that would plug into the FPDM end of the vehicle harness? Not only this, but what does everyone commonly do with the 2nd pump wiring? That is to say the wiring required to split the pumps on the fuel hat side. I've seen some use standard 2-pin Deustche connectors for a quick disconnect. Are there empty pins on the existing connector I could use? Also is there any recommended means for splitting wires? Or does everyone just solder the node? I'm wary of creep, and wondering if there's a good way to do it with crimp connections. Oh, and I'm lazy.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
1989 LX Coupe
7.1@99mph
How much power you making to need dual FPDMs?
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
MM's king of Neon's
404 - car not found
17.81@87
Initially in the 520-550hp range, building the vehicle to be 700+ capable. You know, so if I ever decide to slap on a KB or Whipple it's a few bolts and a retune.
Any idea where to get the connector?
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
lethat makes a quick plug and play kit, also for way less money get ahold of black306 on svtperformance, he sells plug and play kits as well
http://westcoastmustangs.com/article...dual_fpdm.html
![]() bone stock from the factory! |
#5 | |
MM's king of Neon's
404 - car not found
17.81@87
#6 | |
No, there are not enough empty slots in the chassis to tank harness connector to add another pair of wires for the 2nd pair of FPDM to pump wires. That was one of the first ideas that came to my mind when doing the conversion. Unfortunately, there is only 1 open slot. Let me know if you have any other questions. :beer:
Derek Dual FPDM conversion HowTo NEW source for modified FPDMs My Whippled '03 Cobra "Bottles are for babies...real men get blown." |
#7 | |
#8 | |
MM's king of Neon's
404 - car not found
17.81@87
Welcome to MM by the way. ![]() My connectors came in from Tousley yesterday. Alternator extension harness is supposed to be in Friday from Napa. Now just trying to get some teflon/nylon shoulder washers for the hat connections.
#9 | |
![]() I haven't sourced the washers, but I've have really good luck with fasteners from Orchard.
#10 | |
MM's king of Neon's
404 - car not found
17.81@87
The tough part is finding a place around here to get them. All we've got in town is a Lowe's (useless) and a Rural King. I'm going to try a hardware store about 20min from here, if not there's a place not too far that has them, but I have to buy a pack of 40 for $3. Either way it will get done.
1989 LX Coupe
7.1@99mph
I did 650+rwhp...single stock FPDM...with room to grow on all stock parts...
This is why I asked. I don't spend money unless I have to.
#12 | |
MM's king of Neon's
404 - car not found
17.81@87
Of course we'll find out when I go to fire it up if I did it correctly.
Wicked, when I did my dual fpdm, I just used a pigtail I cut out of the v6 mustang. Wired it up and was good to go.
Yours should be good to go... BTW when you gonna fire that thing up???
#14 | |
MM's king of Neon's
404 - car not found
17.81@87
The plan was to get it going last weekend, but for some reason my "quick disconnects" in the fuel system aren't so quick to disconnect. Not sure if they've rusted or what, but I couldn't get any of the 3 to disconnect. No luck with pre-filter, post-filter, or at the hat. I know it wasn't the tool or technique, because it worked just fine on the 2 disconnects of my Cobra tank. Hopefully I can get this mess sorted out by the weekend. ...and then once I verify that works it's time to get down to business pulling the engine. I'll make sure to post up some pics of the wiring once everything is installed and functioning properly.
Threads Similar to: Dual FPDM Time!
| Noob question dual cats dual exhaust? | debar252 | 2005 - 2010 V6 | 4 | April 13th, 2011 02:46 AM |
| Dual FPDM Question | Willy Mo | 99-04 | 16 | March 26th, 2011 11:04 AM |
| dual FPDM vs. modified stage 1 fpdm.... | BakerFX4 | 99-04 | 44 | January 2nd, 2011 09:25 PM |
| need advice between 2 dual brands...Pypes dual kit or GT takeoff dual kit | stangman23 | V6 Mustangs | 15 | May 13th, 2009 06:21 PM |
