1990 Mustang LX
Window problem!!!!!
Hi, I have a 1997 Cobra and I have a confusing problem
My window will not go down I changed out the motor the fuse the button and I tested all the wiring! I am getting current from the bottom all the way to the relay back to the motor and still nothing will move. It makes absolutely no sence to me! I have tried everything I can think of I took wire and connected it to my batter and tried to run a straight connection to the motor and still not even a budge. I am all out of ideas someone please help me!!! Thanks for your help and reading.
500+ with AC, I cant complain lol
2003 Mach 1
13.1@108
When you press the button, do you hear the window motor running/whining or anything?
03 Mach 1 03 SVT Cobra
76 Cobra 2
Will the window go up or down when you have the motor taken out. Also check the grounding.
1990 Mustang LX
There is no noice coming from the motor but every once in a noice from the relay that's about it
And to answer the other question, No the motor does not move out the door at all
2003 Mach 1
13.1@108
I had the same problem a while back with my old mustang, some aftermarket window motors are a little thicker than that stock window motor, and i when i tighten up the bolts on the new aftermarket window motor it some how bound it up. So i unfortunately had to loosen the bolts up a bit to let the motor run freely without binding. So you might want to give that a look at
1990 Mustang LX
I already did that
And I don't even hear the motor even tryig to move And when I click the button I can even hear the relay clicking and nothing happens
2003 Mach 1
13.1@108
Faulty Motor?
1990 Mustang LX
I took the motor out and connected it to the passenger door and it worked perfectly
99 Cobra, 03 Mach1, 07 CS
If I'm not mistaken, the motors are side-specific. Did you actually install the new motor into the passenger door or did you just hook it up to the wiring with the motor loose?
![]() 2007 Redfire California Special http://i183.photobucket.com/albums/x...n/2007GTCS.jpg 2003 Dark Shadow Grey Mach 1 http://i183.photobucket.com/albums/x...born/Mach1.jpg 1999 Black Cobra Vert |
1990 Mustang LX
I just hooked it up to the passenger door
And kept it in my hand
Threads Similar to: Window problem!!!!!
| Window Problem | lariamtox | V6 Mustangs | 6 | August 12th, 2009 09:16 PM |
| Window Problem | kevio | 2005 - 2010 | 4 | July 18th, 2009 05:24 PM |
| Window Problem | exrider23 | V6 Mustangs | 1 | November 12th, 2007 05:48 PM |
| window problem | baine21225 | 5.0 Mustangs | 1 | September 21st, 2007 06:03 PM |
| Window Problem | eLp | Audio/Video | 1 | April 22nd, 2007 04:33 AM |
