Another Happy Aussie supercharged 5.4 DOHC >>
Old October 19th, 2011, 12:51 PM   #1
Mod Mustang Racing is on a distinguished road
We wanted to share this customers great ride and story with the corral gang!
It is a Aussie Falcon with KB 2.8LC (not the black one recently sent to australia that we posted about)
"thought I'd drop you a line to let you know the outcome with the alloy short block you sent me earlier this year…
Fitted into my car, combined with 4v heads, some very mild cams, a Kenne Bell 2.8 LC intercooled blower it has exceeded expectation!
In the end, we held the power BACK to 442 rear wheel kw, (spot on 600rwhp) at only 10PSI. We were all very pleasantly surprised.
I have now done nearly 10000 miles with this combination including several circuit days, and a standing start top speed event. Came 4th overall in that, beat lambo's, Ferraris, Nissan GTR's, Porsche 911's etc etc etc! Kicked arse! Only beaten by a modified Shelby Supersnake, a Leman racecar, and a Australian championship winning endurance race car.
We have plans to up the boost in the next few months once an upgraded fuel system including surge tank is developed for the car. 15psi, and 700 rear wheel HP is the aim. this car remains my 'daily transport', it drives me to work, fetches the groceries, AND indulges me in my motorsport activities.
Mark, you guys produce a quality product, one that I have recommended to several fellow enthusiasts in Australia, and at least one I know has since ordered an engine from you as a result of my own experience.
I think it's important to provide good feedback where appropriate, and that is the intention of this email! please let your engine builders know there is another very happy Australian customer, and pass on my thanks. I would be happy to provide a 'reference' for any potential custom in this part of the world - so please keep that in mind should you be asked for any references for your products.
Thanks again, and best regards
Shane W.
Here are his specs:
Engine
GTWS alloy engine block
Manley forged pistons, Total Seal rings
Manley forged 'H' beam connecting rods
Forged Kellogg crank
Clevite race series bearing
Rotating assembly balanced and blueprinted
Mellings oil pump
Engine oil heat exchanger
Felpro gaskets
Underdrive pulley
Cool thermostat
Oil catch can
Relocated dry cell battery
Heads
Stock Boss 302 4V,
Crow GTP series camshafts
Induction
Kenne Bell 2.8LC twin screw supercharger, polished
Liquid cooling to compressor - electric water pump heat exchanger set up
Blue Power Racing Developments spec rear compressor entry & lower inlet manifold
Blue Power Racing Developments spec front mount intercooler set up
FRPP polished billet alloy twin 65mm throttle body
Blue Power Racing Developments cold air induction, KN filter
10 PSI boost pressure
Fuel delivery
Kenne Bell boost-a-pump
Stock intank pump
Hi flow injectors
Exhaust
Di Filippo 4-1 stainless steel headers
Di Filippo catalytic convertors, 200CPI
Di Filippo 'Big Boy" twin 3' stainless steel cats back
Driveline
Malwood billet steel flywheel
Malwood Option 4 ceramitallic cushioned single plate clutch & pressure plate
Malwood spec slave cylinder
Malwood spec braided clutch lines
Motul race spec clutch fluid
Stock Tremec 6 speed
Harrop Engineering Tru Trac differential centre
FRPP 4.11 final drive ratio
Super pro differential bushes, HD differential bolt
Suspension
Bilstein dampers front / rear
King springs front / rear
Whiteline adjustable swaybars front / rear
Superpro front control arm bushes
Nolathane swaybar bushes front / rear
Nolathane HD sway bar links front / rear
Nolathane spring seats front / rear
Tires
Continental Extreme Contact DWS
245/35ZR19, 265/30ZR19
Brakes
Front;
DBA 5000 series 355mm drilled & cross slotted rotors
Goodrich braided brake lines
Brembo 6 piston front callipers, Ferrodo DS2500 pads
Rear;
PBR single piston callipers, Ferrodo pads
Brembo 330mm drilled solid rotors
Motul race spec brake fluid
Worlds Fastest Automatic Modular - 6.48@220 Worlds Fastest GT 500 - 6.99@205 , Worlds Fastest 5 Speed Mustang 8.99@154 www.modularmustangracing.com
Old October 19th, 2011, 11:19 PM   #2
Because Racecar
Calogero6685's Avatar
2012 Mustang GT Premium
Calogero6685 will become famous soon enough
Since when does Ford Racing make a 4.11 gear? I thought that was GM?
Pictures didn't show!
...I want pictures!
2012 | Ford | Mustang | GT | Premium | 401A | Brembo | 3.73
BMR Suspension | Mickey Thompson | Billet Specialties
I'm tired of all our free bananas being raped at the hands of horny female Islamic fruitists.
BONER CREW EMPLOYEE - URANUS DISTRICT MANAGER
Old October 24th, 2011, 12:56 PM   #3
Old October 24th, 2011, 01:01 PM   #4
C Mor Semen
SNmustang95's Avatar
1995 Mustang GT
Not fast enough
SNmustang95 is just really niceSNmustang95 is just really niceSNmustang95 is just really niceSNmustang95 is just really nice
damn it. that is such a sick looking car!
Originally Posted by 4.6DreameR View Post
I would hit it like the fist of an angry God!
Originally Posted by cotton View Post
just wasted my whole night on this thread
Originally Posted by HurrycaneStang View Post
Wait till you waste your entire life on this forum...
MAC CAI, SLP LM1's, Steeda short throw shifter, UPR O/R X Pipe, 3:73 gears, and more to come.
Old October 24th, 2011, 03:11 PM   #5
MM's Anti-Hardparker
08blkgt500's Avatar
2008 Shelby GT500
08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of08blkgt500 has much to be proud of
we need falcons out here in the usa
MM Cobra Club #24
Old October 24th, 2011, 05:34 PM   #6
EVO LVR
03Black2v's Avatar
2003 Mustang GT
.3 @ 246927429243
03Black2v is a jewel in the rough03Black2v is a jewel in the rough03Black2v is a jewel in the rough
Damn right we do.
I love GTO's!
Threads Similar to: Another Happy Aussie supercharged 5.4 DOHC >>
My aussie ute aussieeleanor All Other Vehicles 12 May 30th, 2010 12:33 PM
What is better for the Street? 4.6 DOHC, 4.6 DOHC SC or 5.4 Lightning SC Steele6599 99-04 61 May 15th, 2008 11:22 AM
Aussie Aussie Aussie!!! obdnanr The Clubhouse 12 April 6th, 2008 11:54 PM
Hey everyone, im another aussie! ridehustle New Members Introductions 8 October 18th, 2006 09:03 PM
Yet another Aussie Flash635 New Members Introductions 7 October 17th, 2006 05:47 PM
