2001 cobra
irs dig??
hey guys i have a 01 cobra and of course have irs , and alot of wheel hop so how the hell do you all do races from the dig without having all that wheel hop? is it ok to do digs with the wheel hop? i hate that shit lol
![]() SVT all day! Next mods: Mickey thompson street radials, new wheels, gears and tuner, then turboed by 2013
2001 cobra
bumpp please need help
2004 Mach 1
12.57 @ 111.72
Steeda Stop The Hop Pak - Cobra - 1999-2004 Ford Mustang 555-2341
Better yet, trade it for a SRA + cash on their end
2004 Azure Mach 1 - K&N FIPK, 3/8" intake spacer, SCT Tuned, BBK O/R X, Magnapack CB, Tri-Ax, Built 31 spline diff with Eaton Truetrac, 4.10's, MM LCA's, Raptor shift light 2004 Mustang GT - Sold |
2001 cobra
damn i was hoping there was a way that was free lol, but thanks for the help so basically i cant do dig races till i buy a package like that or trade for solid rear axle
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
full tilt boogie racing makes a great delrin bushing kit. this will accualy save you in the long run. 99-01 cobras have a weaker irs than the 03-04 cobras so they tend to break during wheel hop
![]() bone stock from the factory! |
2001 cobra
yea i know, so i shoudnt be doing dig races till i get a bushing kit?
2003 mustang v6 ;)
slow
i wouldnt, i would get a irs brace and the bush kit then dig race all you want
2001 cobra
yea all i do is roll races and what not, but i have to keep telling the camaros and other mustangs that want to do a a dig that i cant, and they think i cant drive because they think im making this all up about the wheel hop a messing up my car
#9 | |
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
1989 LX Coupe
7.1@99mph
^ correct.
Wheep hop does come from the stock bushings being rubber and crap. But even after I completely redid everything in my IRS, I still would get it at times on certain roads. Tires and Track/Road is what plays in wheel hop more than bushings and tie rods and axles and what not. Heres what I suggest being down this road more than once. First things first...you get wheel hop. GET OUT OF IT! Don't continue in the gas till it goes away. This is how you WILL break an axle. Been there. Second/First mod, IRS brace. This is a must. Period Next, Poly IRS diff bushings Subframe connectors (id tell you to get this even on a SRA car) Last...get a different set of tires. My BFGs, didn't hop as much as my Nittos, and way less than my Cheapo-tomos (sumitomos) Do that, and I bet 90+% of your axle woes will be gone. Biggest thing...tires. Tires...
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
1999 mustang cobra
![]() iTrader: 1 reviews
Kkkkk first lower the car so the axles of the IRS look parallel to the floor. And make sure to use stiff springs when lowering the car.. and get some solid differential bushings to eliminate the bump you get when you put it into first and during shifting... Also you might want to get adjustible swaybar endlinks due to lowering the car.. And get some good tires nt555 work well
Black and White Crew Crew Member # 5 Check garage for mods and pics if you Los Angeles and want to ride send me a text (323) 270-6827 0% Wheel hop, 0% broken parts, 100% wheel spin |
1989 LX Coupe
7.1@99mph
Endlinks are not needed
Lowering the car isn't the problem. Changing to a stiffer spring rate MIGHT help, but springs aren't the problem Tires.
2003 SVT Cobra
Neverenough nailed it.
#1-if you experiance wheel hop then get out or youre going to be replacing half shafts. #2-a tire with a softer sidewall will make a world of difference. Just about any drag radial is going to be better for you then a 'standard street tire'
![]() 03 Cobra-Slow 02 SS, 00 Z/28-Gone Rest In Peace Travis Billings
