Mach Trans Input Needed
Old October 22nd, 2011, 10:44 AM   #1
The Deer Hunter
Megawatts88's Avatar
03 Mach Clone
Megawatts88 will become famous soon enoughMegawatts88 will become famous soon enough
Send a message via AIM to Megawatts88
Alrighty everyone, I have been having some issues with my trans and I want to get some input on it.
Firstly, I have done some research and I think I may know what is going on but I want to describe it completely so I can get y'alls input seeing as how this is my first manual and I am still learning.
When I did my engine rebuild I took the trans to a shop and had them inspect it to see if it needed to be rebuild because it was making some noise. The shop said everything was fine except for the shift work which had to be realigned.
My problem is when I am driving in a high gear at low rpms. I get a grinding sound coming from the transmission and the volume varies based on rpm and gear. 1st and 2nd gear almost never make this noise but 3rd 4th and 5th will make the noise when the rpms are down around 1k....The worst gear is 5th and its makes a very loud grinding noise when in that rpm range. In all the gears this noise will diminish and completely cease with higher rpms and I never have the sound when cruising at highway speeds.
I dont have any trouble shifting into gear and I have checked the fluid and it is good and I used royal purple fluids so its a quality fluid.
Everything I have researched is leading me to believe I am going to need to rebuild it but I just want to get everyones input.
Thanks
Do not seek in others what you must find in yourself.
Seek first to understand, then to be understood.
Old October 22nd, 2011, 08:20 PM   #2
gdl
99 Cobra, 03 Mach1, 07 CS
gdl has a spectacular aura aboutgdl has a spectacular aura about
I seem to recall from back when you did your swap that you were having some issues with the trans mount and cross member. I never saw whether you resolved that issue or not. Just a thought, maybe the trans mount has broken and you're getting a metal-on-metal resonance. I'm probably completely off-base but at least this is something real easy you could check before you bite the bullet to have the rebuild done.
2007 Redfire California Special
http://i183.photobucket.com/albums/x...n/2007GTCS.jpg
2003 Dark Shadow Grey Mach 1
http://i183.photobucket.com/albums/x...born/Mach1.jpg
1999 Black Cobra Vert
Old October 22nd, 2011, 09:27 PM   #3
Supra's Avatar
2004 Mach 1
12.57 @ 111.72
Supra is on a distinguished road
My previous GT I had with the tr3650 developed a grinding noise a year after I bought it. Only really noticeable when it was in 5th gear though. Drove it for 2 years like that, never had any problems with it otherwise. Still not sure why exacty it did that, Was kind of annoying though.
2004 Azure Mach 1 - K&N FIPK, 3/8" intake spacer, SCT Tuned, BBK O/R X, Magnapack CB, Tri-Ax, Built 31 spline diff with Eaton Truetrac, 4.10's, MM LCA's, Raptor shift light
2004 Mustang GT - Sold
Old October 23rd, 2011, 03:00 PM   #4
The Deer Hunter
03 Mach Clone
I am going to see if I can get a recording of the sound in a little bit.
Been trying to find a good clip of what it sounds like but no luck so far.
My biggest concern is making sure it is fixed before it decides to break on me.
Old October 23rd, 2011, 03:08 PM   #5
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
just a little info for you my buddys tr3650 in his 03 mach is getting rebuilt right now because they are junky trans it didnt even get over 60k miles out of it. before it started grinding in 2nd 3rd and 4th. The syncros were bad. And he drives like a old lady
Old October 23rd, 2011, 11:44 PM   #6
TRMach1's Avatar
2003 Mustang Mach 1
TRMach1 is on a distinguished road
No, they're not a "junky" trans. Like everything else in the mechanical world, some have problems and some don't. I don't have problems with mine, and I don't drive like an old lady, and it handles more power than it was ever intended to!
2003 Torch Red Ford Mustang Mach 1 5-speed
657 RWHP 635 RWTQ
My Mods
My Car
MODS: Yeah, it's got mods.
August 2012 AmericanMuscle.Com Calendar Centerfold!
Old October 24th, 2011, 09:40 AM   #7
The Deer Hunter
03 Mach Clone
Unfortunately I wasnt able to get a good sound clip of what it is doing.
I need to find a good place in Pensacola to take it to get it looked at.......anybody have any recommendations?
Old October 26th, 2011, 12:31 AM   #8
1989Gt.'s Avatar
1989 Mustang GT
Well tell that to his rebuild bill I'm just saying t45 seemed better
Old December 1st, 2011, 02:43 AM   #9
Look Ma! My First Post!
Goddammitanyway's Avatar
Goddammitanyway is on a distinguished road
same issue/tranny swap
I have been having the same problem with the T3650 in my mach but only in 5th and as stated before I am pretty sure that its the synchro. Rather than rebuild it, Im going to drop the junky 3650 and replace it with a custom T56. Any thoughts on that idea?
Old December 31st, 2011, 01:33 AM   #10
The Deer Hunter
03 Mach Clone
Have you done this? If so how did it work out for you?
Old December 31st, 2011, 03:43 AM   #11
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
i vote sychros, face plate it and roll out
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
Threads Similar to: Mach Trans Input Needed
Trans input needed DsmDave 99-04 6 January 27th, 2011 06:56 PM
Your input needed, $10k to spend. Nelson21 99-04 57 December 30th, 2010 09:45 PM
Rebuild Input Needed. bigz5000 4V / SVT 0 August 4th, 2010 11:59 AM
Turbo Input Needed!!! tajoerg 2005 - 2010 40 July 6th, 2009 11:37 AM
