Timing/AFR tables for n/a power
Old October 25th, 2011, 07:36 AM   #1
majorownage is on a distinguished road
How much timing should I be running in a b headed 4.6 with IMRCs?
What about the AFRs?
Currently I have a stock thermostat, but I am installing a 160 this weekend.
For now, I just copied the stock max allowed timing tables into the borderline table.
From 3k to 5.5k = 21*
Above 5.5k=24*
I have my commanded AFR set at 12.5 from 3k on up.
With a 160* thermostat I'm hoping I will be able to add more timing mid range.
I don't have a wideband.
1998 Gt full pi swap -Dead and gone
1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver
1998 BAB Cobra-Project
Old October 25th, 2011, 10:23 AM   #2
bitemark46 has a spectacular aura aboutbitemark46 has a spectacular aura about
Total timing or timing advanced from stock?
My total timing is...
0-4k: 34*
4-7k: 32*
A/F: flat 13.0 to 7k.
93 octane.
Stock tstat with one 1/8" hole drilled in it at 12 o' clock.
-Mark-
98' N/A Cobra (Stock longblock)
11.79 at 114.64 (1.62 60ft)
Old October 25th, 2011, 10:38 AM   #3
0-4k: 34*
4-7k: 32*
93 octane.
Boy thats a bunch. With imrcs I shouldn't require that much correct? (of course while they are closed)
Old October 25th, 2011, 02:56 PM   #4
No, with the IMRC's you don't need as much. I only added a lot to make up for the torque loss in the lower rpm range with my deletes.
-Mark-
Threads Similar to: Timing/AFR tables for n/a power
Timing=Power? PhillyGT 5.0 Mustangs 47 May 2nd, 2010 09:45 AM
pool tables HBK_2007 The Clubhouse 20 December 10th, 2009 04:18 PM
Inversion Tables 2006GTARPD3 The Clubhouse 16 December 1st, 2009 02:15 PM
Advancing timing=how much power? 8A_Honda 5.0 Mustangs 29 September 9th, 2007 01:10 AM
