1998 svt cobra
13.00@104
shortrunner mod?
Hay guys what's up dose any one have the how to for the short runner modd I cant find it anywere
![]() sponsored by auto service and performance and allegheny county customs 98 cobra mods-flowmasters 40s bassini x pipe underdrive pullies diablo tuner pro 5.0 shifter 373 gears 1999 big block project car
2003 gt
5.4 32v on the way
Talking about a short runner intake? Requires cutting up your intake to shorten the length of the intake runners.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
1998 svt cobra
13.00@104
Yeah that's what I was asking about I was trying to find out how much to cut off, and how to seprate the runners from the intake and what's needed to re attach them
MM's Orangest
2004 Mach 1 Mustang
It's not worth it on a bolt-on car. You may even lose power.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
MM's king of Neon's
404 - car not found
17.81@87
![]() Short runners are for high RPM, high flow rate high power applications. Kiss low end torque goodbye with short runners. Short runners = low velocity, high flow rate.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
You guys are both wrong. I did a shortrunner on my car and I picked up 4rwtq at peak. Under the curve was identical to the numbers before I cut the runners. For my bolt-on car, I picked up 16rwhp and 4rwtq at peak. Under the curve it was as high as 30rwhp.
OP, you'll need a torch that uses MAPP gas. Propane doesn't get hot enough. Cut 1.5" off the runners and glue them back in with JB Weld Industro. Gasket match the ports to the IMRC's and file down the bosses.. Google "David Simmons short runner intake". I forgot the link but he has pics an a step to. Not sure if the site is still up though.
![]() -Mark- 98' N/A Cobra (Stock longblock) 11.79 at 114.64 (1.62 60ft) |
Authorized Vendor
![]() Join Date: Feb 2009
^ Correct.
If it is done properly....low and mid range will stay where it's at....and the upper curve will gain tremendously.
Kelly Aiken "The Ford Guy" BMR Suspension Inc kelly@bmrsuspension.com 813.986.9302 CLICK IF YOU LIKE BMR SUSPENSION |
1998 svt cobra
13.00@104
Thanks for the info when I do this I'm going to port the intake and maby the heads my self
#9 | |
4v Know-it-all
A properly made short runner, B head intake adds 15-20rwhp without hurting mid range hp or tq. |
MM's Orangest
2004 Mach 1 Mustang
Then why did your short runner lose power on ModularSpeed's car? Is it because his car was a C head? I'm not trying to be a dick but I was basing what I said off of the results of your intake.
#11 | |
4v Know-it-all
Also, I said that my 8" short runner had issues on his car. The 10" and 5", "C" short runners work great. |
+1.........
#13 | |
MM's Orangest
2004 Mach 1 Mustang
#14 | |
4v Know-it-all
For C intakes they range from 10"-8" and the 5.5." The 8", for some reason, works great with FI but sucks on n/a combos. The 5.5" kills tq and mid range but kicks ass up top. The 10" has minimal midrange and tq losses and moderate peak hp gains but slows the drop off of power after peak, making abour 30rwhp more at 7k. |
1998 svt cobra
13.00@104
ok i shift my car at 7200 rpm so would this defently be worth it for me and thats a stupid question because any hp is good hp im just looking at whats best for drag racing
4v Know-it-all
1998 svt cobra
13.00@104
cool ill have to get started on it in a week or so
