going with forced induction
View Poll Results: what should i go with
procharger 4 23.53%
eaton 0 0%
kennybell 5 29.41%
vortech 1 5.88%
turbo 7 41.18%
Voters: 17. You may not vote on this poll
Old November 3rd, 2011, 06:19 PM   #1
K7cobra's Avatar
1998 svt cobra
13.00@104
K7cobra is on a distinguished road
hay guys im going to go with a supercharger or turbo im not sure what one i want yet any one that has eather a supercharger or turbo plz let me know what the goods and the bads are im forging my internals over the winter and i want to push about 20psi and still keep my cobra street leagle let me know what you think i should go with a kennybell, eaton, procharger, vortech, or turbo of some sort. and remember im not made of money.....
sponsored by auto service and performance
and allegheny county customs
98 cobra mods-flowmasters 40s bassini x pipe underdrive pullies diablo tuner pro 5.0 shifter 373 gears
1999 big block project car
Old November 3rd, 2011, 07:40 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
it depends what you consider smog legal, if your state requires a smog sticker like cali does for performance parts added then i would say stick to supercharger. if not a proper sized turbo always nets good power but can be a pain to install. i run a whipple 2.9 on my car with the stock 7.5 crank, and 3.5 upper and make 18# of boost. if you go centri a budget build would be a ysi trim for 3100, then buy the brackets and fab your own ic up. a d1 is ok but your really going to be pushing it so i would say a f1 from procharger is the better choice but it is expensive.
stay the hell away from eaton!
bone stock from the factory!
Old November 3rd, 2011, 08:05 PM   #3
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
if you have a welder and can do pipe work, turbo gets my vote. thats the way i plan to go within the next few years. otherwise, ProCharger!
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old November 3rd, 2011, 09:34 PM   #4
stal94gt's Avatar
2003 mustang v6 ;)
slow
just a friendly reminder if you choose procharger, spend the extra for a f1 with the 3 core ic. you will see lots of power with that combo rather than trying to turn the snot out of a p1-d1sc.
Old November 5th, 2011, 01:06 AM   #5
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
I voted kenne bell, because this video makes me cum my pants... That noise is everything.
MM Cobra Club #66
Old November 5th, 2011, 03:47 PM   #6
K7cobra's Avatar
1998 svt cobra
13.00@104
Why do u say stay away from eaton
Old November 5th, 2011, 10:36 PM   #7
908ssp's Avatar
2010 Mustang GT
908ssp is on a distinguished road
Whipple. But 20lbs is a lot of boost and you should expect to spend $20 to $30 thousand to get that and have a drivable car.
For a really nice street car 450rwhp from a Eaton is ideal. Eatons run cooler than screw blowers at normal driving speeds and they only have a disadvantage when asked to do more then they are designed for. The refined roots of a Eaton or TVS is a fairly small SC so 450rwhp to 500rwhp is about the limit and they don't make any bigger.
Old November 5th, 2011, 11:03 PM   #8
GearedGT's Avatar
04,99 Cobra-96 GT
GearedGT will become famous soon enough
I vote turbo!
I roots type blower is going to be more fun on the street, from light to light and such, but from the look of your sig, you like to track your car.
I'm not sure what your power goals are, but whatever it is, you can get there on less psi with a turbo. 20 psi on a roots blower? Get ready to replace belts, and clean up belt dust often.
Have you checked these guys out?
Turbo Kits for Ford Mustangs
04 Cobra: 2.8 upper/4# lower, cai, o/r xpipe, catback, short shifter, irs brace, 93 tune.
99 Cobra: full exhaust, cai, 3.73's, short throw, bama tune
96 GT: stock and awesome.
Old November 6th, 2011, 01:39 AM   #9
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
iTrader: 10 reviews
this is going on your BAB cobra, right???
if so you are kind of limited on your options of a roots blower unless you would swap from your stock B heads to the later C heads.
that would open up ALOT more options
BSD 100MPH Club
YMR #8975
MM Nitrous Club #7
MM Cobra Club #87
Old November 6th, 2011, 04:20 AM   #10
stal94gt's Avatar
2003 mustang v6 ;)
slow
Originally Posted by GearedGT View Post
I vote turbo!
For the power your looking to make op it is best to buy the right size sc for what you want.turning a small blower fast enough to make big numbers will cause problems with belt slip and wear. Getting a large sc made to push bog boost will require less service and longer life on the sc. I run a whipple 2.9l on my cobra and have never chewed up a belt or had extensive dust cause I run the stock upper and lower pullies and make 18# of boost. That is why I say stay away from the small superchargers like eaton and p1sc
Old November 12th, 2011, 02:26 PM   #11
K7cobra's Avatar
1998 svt cobra
13.00@104
hay guys sorry i havent responded for the past few days my computer crashed. my whole goal is to run 10s im running 13.30 now with the mods i have listed in my sig. with full bolt ons im sure i can hit 11s at least high 11s. i called on 3 performance for the whole kit it will cost me about 3200 with the k member and master turbo upgrade with out it it will be around 1900. it sounds like it will be a great deal with the way things are now i might hold off on the turbo untill next winter.
Old November 13th, 2011, 01:25 PM   #12
codycat91's Avatar
2003 MUSTANG GT
codycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the rough
iTrader: 10 reviews
What CR are you going to be running?
4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton
4v MMR Stroker 1000 / Posi Race Ported Eaton Build
How To: 2v to 4v COP Swap
Old November 13th, 2011, 08:09 PM   #13
K7cobra's Avatar
1998 svt cobra
13.00@104
This is a stupid question what is cr
Old November 13th, 2011, 08:26 PM   #14
99Ls1fever's Avatar
2ndPlaceSetofSteakKnives
99Ls1fever is an unknown quantity at this point
Vote was Turbo.
I would think that you might want to look and read this thread.
On3 Performance Turbo Kit Install
The kit is 2300 out the door to your house. I am running the same kit. There is a 45x or 46x dyno sheet in there on his car running 8psi and fuel cut at 5.5rpms. i believe after he fixed the fuel issues he was over 500hp on 8psi. thats impressive power for the buck..... Hard to not give this kit a look
03' Cobra | 3.4 Whipple | SRA Swap |
99' SS | Forged 347 | YSI 16psi | 12 Bolt |
96' Cobra | On3 FF Kit | T45 Source Tranny | 3.55's |
91' GT | GT40 Intake | CAI | Headers |
www.fquick.com/99Ls1fever
Old November 13th, 2011, 09:52 PM   #15
codycat91's Avatar
2003 MUSTANG GT
iTrader: 10 reviews
Compression Ratio
Old November 14th, 2011, 11:13 PM   #16
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
Turbo no diubt
Threads Similar to: going with forced induction
forced induction? KillerSwinger 2005 - 2010 11 October 14th, 2011 11:40 AM
Forced induction? shroom 99-04 4 June 2nd, 2007 12:20 AM
NOS vs. Forced Induction zkid01 99-04 29 April 10th, 2007 04:18 PM
Forced Induction Mustang RacR94 V6 Mustangs 30 March 28th, 2007 10:06 AM
Forced Induction FUn trueballerisme V6 Mustangs 122 February 28th, 2007 01:27 AM
