#21 |
4v Know-it-all
#22 |
So on a mark 8 motor the cams arent meant to turn past 6k rpms huh? its pretty much a waste? Is that because the lack of duration in them?
MM FOBRA CLUB MEMBER #1 |
#23 |
4v Know-it-all
#24 |
What rpm? Like 4000
#25 |
1997 Thunderbird
14.06 @89.53 needs tuned
With the exception of the LSC intake the difference between the 93 and 96 is that the 96 has a larger oil pickup tube and matching pump. It helped to prevent the lash adjuster and follower failures that these motors were prone to.
Alan
I don't check in here anymore, for those that want my opinion and assistance call me. The politics and drama of this forum are too much for me. (513)898-1580 |
#26 |
4v Know-it-all
#27 | |
Ok i thank you for the info! What capability does the cast cranks have as far as revs?
#28 |
4v Know-it-all
#29 |
Ok i was just wondering cause i have a ford racing cast crank, how much boost do you think that car will handle if i have forged pistons and connecting rods, then the cast crank.
#30 |
i didnt mean boost i meant nitrous
#31 |
4v Know-it-all
#32 |
They were manly pistons and mmr forged steed rods, total seal rings filed for 150shot .22 if im not mistaken.
#33 |
Yep! They're the strongest aluminum block from factory, and i think you can shove 52lbs of boost down their throat? Thats the block ill be using for my future 5.0 stroker build. Cant go wrong with a Teksid
1969 Ford Mustang GT Grande Coupe 331 Stroker Street/Strip car, The Sweet 69 1966 Ford F100 400 Boat ancor BBF, blown C6 trans, different engine combo soon. The Sweet 66 ![]() My lug nuts require more torque than your Honda Civic makes |
#34 | |
4v Know-it-all
The Teksid cannot withstand 52lbs of bost in stock form. The racers that are pushing upwards of 40psi with them are using two cooling systems, one for the heads and one for the block. The cooland passages in the deck surfaces are welded shut so no water passes between the block and heads. The reason for this is that under pressure they couldnt keep the coolant from blowing out. Teksids aren't event he strongest aluminum blocks, the 05 and up aluminum block, teh one used in the Aluminator engines and the 3vs are even stronger. However, in a street driven combo, a standard WAP aluminum block will hold up to whatever you can throw at it. |
#35 | |
#36 |
4v Know-it-all
#37 |
What kind of high temps are we talking here?
#38 |
1997 Thunderbird
If anything the aluminum block dissipates heat better. Heads are easily damaged by overheating more than the block is. Any motor that exceeds about 250 degrees and you plan to rebuild it should have all the castings planed or at least checked.
Alan
#39 |
1999 Mustang V6
That's exactly what I want to do to my 99 Mustang! Hope everything goes well! Hopefully I can find a good deal on a mark vii engine like you did
Threads Similar to: 4V Info Needed
| Vortech Info Needed | Nightmare69 | American Muscle | 3 | November 22nd, 2010 12:08 PM |
| Wiring info and axle info needed | Mustang7125 | 96-98 | 4 | October 12th, 2010 08:21 AM |
| 8.8 info needed | rru95GT | 94-95 | 9 | June 23rd, 2009 09:48 PM |
| supercharger info needed | Black02GT | 4V / SVT | 11 | April 28th, 2008 11:03 PM |
| tire info needed!!!! | dkg2673 | 99-04 | 1 | February 29th, 2008 07:59 PM |
