1998 mustang cobra
whats the deal with twin turbo stangs and cylinder 1 problems?
So i've came across several engine's for sale on several forums. I see these engines for sale either with damage to cylinder 1 or previous damage thats been fixed. All of them say the engine came out of a twin turbo cars. I have missfire in my cylinder 1 as well. whats the deal?
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup) comin soon...ON3 turbo kit, PTE7175 |
97 cobra
might look into the cooling head mod. i dont remember which cylinder would always over heat when high boost was added, but thats why they do it.
1999 mustang cobra
![]() iTrader: 1 reviews
Cylinders #8 I believe is the one that tends to heat up with out the head cooling modd
Black and White Crew Crew Member # 5 Check garage for mods and pics if you Los Angeles and want to ride send me a text (323) 270-6827 0% Wheel hop, 0% broken parts, 100% wheel spin |
1998 mustang cobra
i have the cooling head mod already, which cools cyl 8.
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
Hey buddy what's up? I was going to text you about this but figured I'd post it for other people. Since the first cylinder sees boost the quickest, the rings are hit the hardest by all the added atmospheres from added boost. If the rings are improperly ground or just the wrong type for the build these problems will happen, and you will get blow-by. Where air bleeds into the bottomend losing compression.
2000 Mustang GT Built 4V Motor with Sullivan Single Plane Intake Custom 66MM BB TT kit Borla XR-1 Dumped before rear Moser built 9" Rear 35 spline WaveTrac Diff with 3.75s 35 spline Moser axles 14PT roll cage and minitubbed
1998 mustang cobra
ahh that makes some sense. good info man, thanks
#7 | |
Billy Weston
I don't agree.Most likely a fuel system problem. Cylinder #1 is the furthest foreward cylinder. If the fuel system is not properly plumbed or the pump is not strong enough it will be the first cylinder to starve. While the car is under WOT the g-forces will try to push fuel back against the pump. None of this is seen while on the dyno since the car is stationary. Returnless systems especially have these problems because of the time it takes for the ecu to command more fuel pressure. If a lean spike is present on the initial hit cylinder #1 is going to get it the worst.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
#8 | |
MM's king of Neon's
404 - car not found
17.81@87
To back up this theory, I'm looking at the engines here at work. They're all highly boosted straight sixes with a large common intake manifold. That's a lot more area to cover than our little 4.6L engines. Plus since they're diesel, the design really doesn't give a sh*t about port velocity, so this is an example of an extremely crummy intake design. Yet with all that against it, boost distribution is pretty even. It would be interesting to see if someone could get a set of headers and run tests with a wideband on each primary and compare different intake designs versus fuel rails to see exactly how bad the problem is.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#9 | |
Billy Weston
Sorry, I still don't see it. Most factory motors go on cylinder #8. I guarantee most of those TT motors are aftermarket so that throws your theory for a loop.
BTW where did you get the idea cylinder #1 sees boost first? Do explain.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. Last edited by C MY 4D; November 21st, 2011 at 12:21 PM. |
1998 mustang cobra
well, i have aftermarket rings (hellfire rings to be exact). i also have an aeromotive eliminator fuel pump, sumped gas tank, -8 feed line and -6 return. I have a 98 cobra motor, but i have 97 cobra imrc's plates with flappers deleted. i had the holes welded shut on the imrc plates. maybe the weld sticks out a lil in the hole in Cylinder 1? dunno.
BUUUT i get the missfire under even minor loads, like just going uphill. i get a check engine light on for it. Whats odd is that i didn't get a missfire when i had a supercharger on it. maybe i have a bad injector?
Billy Weston
Well that's easy enough to figure out. I would start with a compression and leak down test. If all looks ok swap in a new plug and swap the wire with another cylinder and swap injectors to another cylinder. Make sure you choose different cylinders for each part moved. If the miss follows a certain part you found the problem.
1998 mustang cobra
yea sounds like a good idea
Threads Similar to: whats the deal with twin turbo stangs and cylinder 1 problems?
| whats up stangs | 5.0MustangLx | New Members Introductions | 10 | February 28th, 2011 10:08 PM |
| Is $3500 a good deal on twin turbo kit | appel1978 | V6 Mustangs | 31 | November 18th, 2010 03:37 PM |
| Twin Turbo Or Twin Screwed? | MikeJones | 99-04 | 61 | October 30th, 2010 10:50 PM |
| Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 | Mellon | Videos | 10 | December 30th, 2006 10:05 AM |
| Super Charger vs Turbo/Twin Turbo: Pros and Cons of each | FireryDriver | 2005 - 2010 | 9 | September 17th, 2006 04:15 PM |
