Water Inlet / Outlet fittings now available >>
Old November 15th, 2011, 12:28 PM   #1
Mod Mustang Racing is on a distinguished road
MMR has released our new water inlet / outlet fittings designed for all DOHC heads including B heads. These allow for custom water plumbing, head cooling mods etc. Water can even be plumbed to the rear of the engine for clean appearance and Front throttle body designs!
From the MMR site:
Want to plumb your water system using stronger and blow proof AN fittings, then you need these. Includes 2 fittings, hardware and O rings. Fits ALL DOHC heads including B heads. Can be used on front or rear location of head - rear location simply requires removal of the factory freeze plug on some applications. Can also be used to join cylinder head passages together for cylinder head cooling mod. Fittings use -12 Size .
$119pr
Worlds Fastest Automatic Modular - 6.48@220 Worlds Fastest GT 500 - 6.99@205 , Worlds Fastest 5 Speed Mustang 8.99@154 www.modularmustangracing.com
Threads Similar to: Water Inlet / Outlet fittings now available >>
muffler size??? inlet/outlet dark_horse V6 Mustangs 6 May 15th, 2010 08:49 PM
Cap water pump outlet sniperd 5.0 Mustangs 2 December 13th, 2009 12:37 AM
which inlet outlet muffler xSxTxAxNxGx V6 Mustangs 2 October 29th, 2007 11:22 PM
mufflers with inlet/outlet on same side danthelion 99-04 2 January 21st, 2007 11:41 PM
